Cap and rotor
Old Apr 28, 2002 | 03:41 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Cap and rotor
Well the other day I took out the IAC and cleaned it all out, which I think partly helped my problem. My car no longer does the rev thing when I start it. But now when I turn it over it somewhat seems weaker of a start? Not exactly sure what the cause of that is. It still starts on the first try, perhaps I'm just paranoid or something. Also when I'm goin' WOT I sometimes hear a click noise or somethign from under the hood. I have no clue what that could be... And I checked for jumping sparks under the hood at night, but I may look again.
It's been about 15k miles since the cap and rotor were replaced. Would you think this would help? I would have replaced it when I did the spark plugs and wires, but funds at the time were low. But my questions are:
1.) What cap & rotor should I buy? From where? And would anyone happen to know the part number?
2.) Can I get a performance cap & rotor even though my wires aren't 8.5mm? That's fine if that's the case becuase then I will just pick up some 8.5mm wires as well, but again, I don't know where to find them for my car!!
3.) The job needs done anyway, but would this perhaps be part of it?
Thanks!
Mark
Old Apr 28, 2002 | 03:51 PM
WaynesRS's Avatar
Your cap and rotor is still good if it only has 15000 miles on it . Usually people get 100,000 out of their rotor . The dist cap should atleast go to 50,000 . Is it just taking you one crank to start the car ?
Old Apr 28, 2002 | 04:20 PM
Engine: 346ci LS1
Transmission: MN6
Yeah, I just crank it over and it starts, it just doesn't feel strong...?
Old Apr 28, 2002 | 04:38 PM
WaynesRS's Avatar
I wouldn't worry about it unless it was hard to start .
Old Apr 29, 2002 | 10:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Glad to hear the IAC cleaning helped... like Wayne said, caps and rotors usually last a long time, but it couldn't hurt to change it anyway- like you said, it needs to be done. You could always clean the cap terminals. Remove the cap (leave the wires on), and remove any deposits from the 6 terminals inside. If the inside of your cap looks like the one at my page, you might want to replace it. Pics: http://www.geocities.com/tomp_3rdgen/burnt-cap.html
The Accel cap is #8133; ACC-8133 from SummitRacing.com, you should be able to look it up by part # to get a price.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tyeo098
Nov 30, 2015 06:27 PM
BLK87Z
Sep 18, 2015 11:29 PM
m00n420
Sep 11, 2015 02:39 PM
