Head Light Motors???
Old May 27, 2002 | 06:55 PM
jeff's Avatar
Does anyone know of a place to buy a headlight motor from other than GM? Don't they run for around $200 at GM? Also, can someone link me to the article someone wrote on them about repairing them, instead of replacing them.
Old May 27, 2002 | 07:34 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You can buy one from the junk yard. Or me..
-- Joe
Old May 27, 2002 | 09:18 PM
trutilldeath246's Avatar
Re-Build the ones you got
Search for Rodney Dickmans Fiero's or something like that. He has rebuild kits which are just little round plastic pieces. He sells them for about 7 or 8 bucks a pair. If I were you I would buy two sets that way you can always repair the ones you have. I did it several times cause I have two Firebirds. after a while you get good at it.
Old May 27, 2002 | 09:20 PM
2vmodular's Avatar
or you can do the quick and dirty fix and never have to worry about the popup headlights again.
unplug the electrical connector from each headlight motor, then turn adjusting **** to raise each headlight. headlights will now remain permanetly in the up position.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
stalkier
Aug 13, 2015 12:59 PM
fonzie85
Aug 13, 2015 11:50 AM
Omega
Aug 10, 2015 12:46 PM
