fuel filter
Old Jun 17, 2002 | 08:13 PM
87Bandit's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8lt V6
Transmission: TH700R4
fuel filter
where is the fuel filter on a 2.8. Im too lazy to look for the freakin thing.
Old Jun 17, 2002 | 08:52 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Under the drivers side of the car, inbetween the back of the driver seat and the rear tire well. It will more likley be dirty as hell, and if it was like mine it should weigh about 3 pounds mine really needed to be replaced.
Old Jun 18, 2002 | 08:50 AM
87Bandit's Avatar
Engine: 2.8lt V6
aight thanx man
Old Jun 18, 2002 | 10:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I worked on a friend's 88 Mustang, 2.3l I-4 auto, once. Thing was running like garbage, and it looked like a tuneup was never done. Think your fuel filter's bad? The 'stang's was completely rusty, and was collapsing. It's in a bad spot, too. It's up behind the rear bumper. I put safety goggles on, and didn't want to reach underneath at all- last thing I wanted to do was get blinded or chemically burned by a frickin' ford.
Old Jun 18, 2002 | 12:35 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: fuel filter
[QUOTE]Originally posted by 87Bandit
where is the fuel filter on a 2.8. Im too lazy to look for the freakin thing. [/QUOT]
it is a real bitch to change. and I would spend a few days soaking it down with some PB blast. Most likley you will twist one of the lines off, if it has not been change in years.
I got a foot long piece of steal braided line and use the filter with the nipple ends. When you buy a new one they will have both on the shelf, both the same size, one with fittings, one with nipples.
1 nipple filter
short pieces of steal braided line
8 small hose clamps. 4 on each side, doubbled clamped.
Makes a hard job easy and replacing the filter a snap.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
