new to 8D, what's the latest and greatest...
Old Jun 22, 2002 | 07:40 AM
Aaron's 87's Avatar
I've got all the info for my 165 ARAP Vette, but I just picked up a 91 GTA to play with. What's the latest ecu file for it - I've got the one from diy-efi ftp. Is there a certain BCC that everyone gravitates to like ARAP? Thanks for the help.
Old Jun 22, 2002 | 10:02 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
AUJP if L98 auto.
Old Jun 24, 2002 | 11:23 AM
Aaron's 87's Avatar
How about ecu files?
Old Jun 24, 2002 | 04:21 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
What about the AXCR (auto) and AXCN (manual)? Can these bins be used as a starting base?
They are from a '91 Corvette 727 ECM (speed density).
Old Jun 24, 2002 | 06:47 PM
Car: Death Mobile
Engine: 666 c.i.
I wouldn't recommend SD Vette Bins for F-bodies. Primary reason being Vette Bins monitor/report the "Oil Temp Sensor" while F-bodies don't have any such input. Even if I converted my L98 Auto to a Manual, I would work with the SD 305 Manual Bin rather than a Vette.
Old Jun 24, 2002 | 10:08 PM
HighHopes85's Avatar
I wouldn't use the Vette calibration in the 3rd gen for a different reason--Aluminum heads on the Vette. Unless you change the heads to aluminum, your spark curves are going to be more off to start off with.
The oil temp sensor code is a simple 2 bit change in the bin (for high and low codes).
Old Jun 25, 2002 | 05:23 PM
Engine: 4.0L
I totally agree about the aluminum heads. Especially if you've ever looked at the spark tables of the Corvette bin! It's a huge differance!
The oil temp could also be simulated with a resister for a standard tempature.
Old Jun 25, 2002 | 06:47 PM
Car: Death Mobile
Engine: 666 c.i.
Basically, I have foudn that Vette Bins seem to have driveabilty problems when used on F-bodies an vice versa. There are lots of "little settings" that differ between the two that make me prefer to use Vette Bins on Vettes and F-body Bins on F-bodies (for SD cars).
I did a Binary Compare on the two when I first got into eprom burning and found virtually every byte different - including the actual code. Lastly, there is extra code in the AUJP that is not in the ANHT. This is the primary reason for all the "instructions" appearing different. I am STILL "documenting" my AUJP Source Code and I'll inform you on the specific instruction differences when I find it.
So while the "Data Portion" for the Vette Bin is located in the same areas as the F-body AUJP, there are many other differences including the source code.
Old Jun 25, 2002 | 09:02 PM
kevinc's Avatar
Car: 1982 Z28
Not sure I agree with the generalization on using Vette bins in F-bodies. If your engine happens to be configured resembling a Vette, eg. aluminum heads, higher compression, 6-speed manual trans, running a Vette bin makes a lot of sense.
As stated above, disabling the oil temp error bits is easily done.
In my case it was the lesser of two evils...either run an F-body bin for an auto trans, or run a Vette bin. Since my engine has Vette heads anyway, no real issue.
Old Jun 25, 2002 | 09:11 PM
Car: Death Mobile
Engine: 666 c.i.
There is also the SD 305 5-speed bin.
The "generalizations" are past experiences trying to resolve "driveabiility" issues that "just won't go away". Usually going with an F-body Bin for 7730 or a Vette bin for 7727 as a "base" and tuning from there was often the only solution that worked to resolve the driveability issue.
I am still concerned about the extra code that exists in the F-body AUJP bin that doesn't exist in the Vette ANHT Bin. When I figure out what that extra code REALLY does (or does not do) I will let you know.
Old Jun 25, 2002 | 10:06 PM
I would be interested to be kept up to date on it. I originally was running the ANHT bin in a Vette platform, but I have iron heads (85, so I had to delete the OT codes). I ran it for a brief time, then decided to go with the AUJP mainly because I figured my combo was more built along the Camaro's engine.
Unfortunately, I made vast Diacom runs with both setups but the CCP system was skewing all of my lower BLMs. At tip-in, when CCP enabled, I got pig rich. It was a hardware problem with the system itself and not actually with my VE tables. So, in the end, I never really knew what my Diacom readings would have been with the ANHT to start off with.
I have a new engine going together...still iron heads but a different cam. I will give both chips a shot and see what calibration gets me closer to start off with. Engine should be baselined ~July 4th weekend or there'bouts.
Old Jun 26, 2002 | 11:40 AM
Aaron's 87's Avatar
So, which .ecu file is the latest and greatest?
1MeanZ
Dec 18, 2015 05:39 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
formula_novice
Sep 5, 2015 03:58 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
Mikes86SC
Apr 10, 2001 08:23 AM
