please photochop z28 spoiler legs
Old Jul 8, 2002 | 02:23 PM
logikal6785's Avatar
can someone do a photochop for me ?
can you pls remove the two middle support struts on the z28 spoiler so that it's more like a wing, and easier to mount ? i just want an idea of the finished product =)
k and ya i am using zepher's car bc it's a great shot for it and i hope he won't mind
Old Jul 8, 2002 | 04:47 PM
redraif's Avatar
Transmission: Th700R4
So then how would you bolt it down??? If you bolted it to the quarter panels how on earth would you open the rear hatch???
Just pondering.
Old Jul 8, 2002 | 06:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Red.. the highrise also has 2bolts per side holding it down to the edge of the hatch panel (at least the A&A one I bought does..).
Here's a crappy PsP hack
Old Jul 8, 2002 | 11:54 PM
HrdRockA4305's Avatar
Yeah, as far as I know, the middle 2 attach it and the end pieces kinda float over the quarters without touching. It'd look cool but I think its too wide to mount properly. Now, my 88 SC aero wing mounts totally on the decklid, but its kinda goofy looking from some angles IMO so I want the 90's Z wing. But like I said I don't think you can mount it that way.
Old Jul 9, 2002 | 12:27 PM
redraif's Avatar
I thought the factory ones hover as well, it looks that way in the pic. Oh well, if the after market ones mount that way, then it could definately work. You would have to be careful doing it. I'm not sure what you would fill the holes in the spoiler with. If its fiberglass that would be no biggy, but if its plastic that would be harder. Don't know how you would fill the holes and have them hold up and look good.
Old Jul 9, 2002 | 03:43 PM
deadbird's Avatar
Engine: TPI 305/ v6
Here's a swiped image from..
http://www.metzcon.com/fbodymanual/12-04.htm
From the looks of it, the OEM wing seems to mount to the edges too. IMO also, it would seem a bit flimsy to just have the center hold the wing to the deck.
Old Jul 9, 2002 | 05:03 PM
Huh how about that, maybe the factory one does mount totally to the decklid. Could it be just the aftermarket ones that don't? I still think it'd look funny from the back if it didn't go all the way to the edges of the body, thats a lot of the reason I don't like mine. The idea with the no centers is kinda cool though, its just making it work is the hard part.
Old Jul 9, 2002 | 06:15 PM
deadbird's Avatar
Engine: TPI 305/ v6
Mine is an A & A Specialties I got from JEGs a good while back, it's supposed to be deadup like the stock one. The outermost bolts are barely on the edge of the hatch deck & the lip on the wing is made to where it looks as if it's not attached from the side (if that made any sense..). It doesn't come out as far on a firebird because the sheetmetal on a firebird is slightly wider in the back.
Here's a larger pic of mine..
Old Jul 12, 2002 | 09:56 PM
Mathius's Avatar
Hmm.. They must have aligned that just perfect to get it to set on the edge there with the power close hatch feature. I also wonder why they put the two middle supports in if the edges are secured to the hatch. I'm sure it adds extra support, but surely someone would have done a mod by now.
Mathius
Old Jul 12, 2002 | 10:41 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
On both ends of the wing there is a screw and a stud which is bolted down .
Old Jul 13, 2002 | 01:21 AM
deadbird's Avatar
Engine: TPI 305/ v6
Mathius
My hatch has the (power close) pull-down motor.
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
F-body-fan
Nov 4, 2015 06:13 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
