Please help--PIC inside
Old Jul 28, 2002 | 04:38 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Where does this wire go? One end is bolted to the firewall, where does the other end go? It looks to be a braided copper wire w/o any insulation.
Old Jul 28, 2002 | 04:46 PM
ede's Avatar
ede
looks liek a ground strap, try to back of the head
Old Jul 28, 2002 | 04:53 PM
Jester's Avatar
what he said.
Old Jul 28, 2002 | 04:55 PM
thank you guys. it would be ok to ground it to the manifold right, or does it have to go to the back of the head?
camaroguy99's Avatar
yep thats what it is. look for some other ground staps on the back of the head. Mine has 3 or 4 attched to the same spot. I'll tell you it is not easy to get those back on when you forget to put them back after the new heads go on.
Old Jul 28, 2002 | 04:57 PM
yeah i have seen those straps. could this cause problems with the interior lights, turn signals and so on?
Old Jul 28, 2002 | 05:08 PM
Jester's Avatar
It sure could.
Old Jul 28, 2002 | 05:57 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
if it's not attached the battery wires from the starter will overheat and catch fire(good thing I had a fire extgisher handy- man that stuff is hard to clean up)
Old Jul 28, 2002 | 06:17 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
thats where mine is, it seems to be fine
It hasnt been attached in a long time. I have had no problems. I just attached it and it did not fix my latest problem, found in this post.
Old Jul 28, 2002 | 07:02 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
All the wire does I think is ground the firewall. I would hook it up to the motor. And your other problem is weird. It may be a bad ground or an open somewhere. By the way in the other pic, I didn't see your tach needle, where you on the gas? gl
Old Jul 28, 2002 | 07:42 PM
i was playing with the gas just for fun. the tach works fine.
thanks
Old Jul 28, 2002 | 09:15 PM
ZRated85355's Avatar
you allready know by now that that is a groud strap so you dont need me to tell you. The ground srap on my car has'nt been hooked up in 100 miles and everything works fine. maybe i should hook it up so my wires dont catch fire
Old Jul 28, 2002 | 11:48 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
You won't roll your eyes when you start having electrical problems! :nono:
In fact, it is a worthwhile mod to take a battery cable and attach it from the engine to the fenderwell in order to provide a GOOD PERMANENT ground
Old Jul 29, 2002 | 12:21 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
Just ground it to something
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
