Air Dam Needed!!!!!
Old Aug 6, 2002 | 10:29 AM
oOSpeedFreakOo's Avatar
Air Dam Needed!!!!!
Does any one have or know wher ei could pickl up an air dam fairily cheap? And if worst comes to worst could someone give me the measurements so that I could have one made out of sheet metal... thanks alot please email me @ welfareracingny@aol.com thanks again
Old Aug 6, 2002 | 10:53 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Just go down to your local gm dealer and buy one. They are any were from $25 to $40 and if not in stock can be ordered within a few days. I would also suggest that next time you use that nifty search feature they have at the top.
Old Aug 7, 2002 | 01:43 AM
LowStyle187's Avatar
Go buy one Mine was $26 bucks straight up...be there in a few days. Ordered it on a friday had to wait til tuesday cuz they were closed
Old Aug 7, 2002 | 02:29 PM
uk89camaro's Avatar
Made mine out of chequer plate. Two pieces, a master and slave. The slave piece is riveted using fairly small rivets, so if it gets busted on a ramp, it'll generally bust a few rivets on the slave, and not bend or break the whole lot.
Old Aug 10, 2002 | 03:45 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Thats one nifty lookin air dam. I bet that doesn't give you any air flow problems under the hood. Our plastic ones probably bend when under high speeds.
Old Aug 10, 2002 | 04:10 PM
uk89camaro's Avatar
Pimprod,
In the UK there aren't many days in the year when you need an air dam. I wired in a manual fan switch for stop/start stuff in the non-winter months (I can't call them summer, cus we don't get them any more), but found even in 75-80* cruising was causing the fan switch to operate frequently between 220-190. The air dam keeps the temps down below 190 when cruising.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
