Please identify these headlight parts
Old Aug 22, 2002 | 03:30 PM
Makai's Avatar
Ok guys, 2 posts down (i screwed up) are pix of what i think are modules or relays for the headlight motors. Some I have replaced. Some I'm not even sure if they are related to the headlights
I've been told there are 3 relays/modules for 86 TA headlights.
The ones between the battery & radiator makes 2 (I think)
Where is the 3rd?
Ok, this oughta help me out alot. Soon as I can identify all the headlight relays, i'll just replace them all, and hopefully this problem will be solved.
Thanx guys!
See below
Old Aug 22, 2002 | 03:33 PM
Makai's Avatar
wire?
I found this wire under the hood, anyone else have this? and where does it go?
And whats that other thing?
Old Aug 22, 2002 | 04:51 PM
Makai's Avatar
pix
i forgot to put this in my first post...duh
Attached Thumbnails Please identify these headlight parts-3rdgen-medium-2-.jpg
Old Aug 22, 2002 | 07:19 PM
Nasty_Bird_'90's Avatar
In the first pic, the wire looks like a ground of some sort, and the little box you point to is the fuel pump relay. In the other pic of the passenger side near the blower motor, that is a relay for the A/C/ heater motor. The power is directed through that when your fan is turned to the "high" position. I'm not sure about the other stuff. They all look like different relays and such to me. hope this helps a little.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
