Turbo made into an SC?
Old Aug 24, 2002 | 03:09 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
I searched for this, but never found anything. I am sure it has been asked before, but I was finding nothing.
On the v6 board there talking alot of turbo and Supercharging again. I've been reading, not really too concerned when I saw an idea and thought I would ask you guys if it was possible.
Can you take a turbo, and make it run as a Supercharger?
I am talking add a pulley to the turbo so it runs off the crank rather then the exhaust?
Someone else had this idea, but I was wondering is it possible to even do?
Old Aug 24, 2002 | 04:14 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
thats a new one on me, maybe you could market something like that. people would probably pay $3000-$4000 dollars for a kit that they could bolt onto thier car.
Old Aug 24, 2002 | 04:21 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Biggest problem is getting the rpm of the turbo up enuf to generate boost. Most SC's other than roots style have a gear multiplication to get the shaft spinning with the required rpm.
Old Aug 24, 2002 | 04:22 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont think he is familiar
Old Aug 25, 2002 | 07:48 AM
Joe_L's Avatar
Car: 1995 Z28
Okay. Well if you could make your own gear setup too will the bearings in a Turbo handle the RPMS?
What I was thinking is there are thousands of those old Daytona Turbo's. But to rig it up to the V-6 requires too much exhaust work. But if you could create a kit to turn the old Daytona's turbo into an SC people would buy it.
Old Aug 26, 2002 | 12:00 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
A friend of mine already did that. He combined a big turbo with a gearbox from an electrical wheelchair ...
Old Aug 26, 2002 | 12:21 PM
Guido's Avatar
Car: 2000 Trans Am
Wow that is pretty novel but good *** what a cluster ****!! lol
Old Aug 26, 2002 | 02:11 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
cobbled comes to mind, interesting routing. vortech and procharger need to learn a lesson here in fresh air routing, kudos to paxton for its 3rd gen fresh air routing as well as those guys that made thier own little fresh air boxes that sit on top.
Old Aug 26, 2002 | 03:25 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Found another picture that shows the supercharger.
These are both old pictures. I think that he is using fourth or fifth version of the supercharger now. The air routing is basically the same, but less rubber hoses and welded pipes instead.
Old Aug 26, 2002 | 07:06 PM
Joe_L's Avatar
Car: 1995 Z28
Thanks JoBy.
The Pictures are a great help.
Those pics will help me in my conquest for the Trubo -- SC conversion which probably won't be happening till next summer. But Atleast I have a bit better Idea on how to build the system.
There is only one thing Joby. Is his SC hooked to the crank I can not seem to locate the belt or is it hooked to the Wheelchair motor?
Old Aug 26, 2002 | 11:50 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
You can see the pulley and belt between the supercharger outlet and the radiator cap.
I must warn you. This is not something that is easy to do. My fried has put a lot of hours into this during the last four years. Presision, strength and balance are critical to make the supercharger last.
I changed bearings in my 10 year old Vortech supercharger.
http://jobyteknik.homeip.net/corvett...arger_rebuild/
morrow
Jan 13, 2024 12:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
