Low oil pressure...
Old Sep 8, 2002 | 05:22 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
Low oil pressure...
Still trying to get my '89 IROC on the road after a never-ending engine rebuild...
Basically, when I start it up (it's a little tough to get started), it will idle high (between 1000 and 1200 RPM), and the oil pressure will be somewhere between 40-45 PSI. I figure that's pretty good. Now, after it's been running for like 10-15 min, I noticed that the oil pressure gague was reading somewhere around 15 PSI -- mabye a little bit more. What really seemed weird to me, though, is that the oil pressure did *NOT* change when I gave it some gas. I could bring it up to 3000 RPMs, and the oil pressure needle would barely budge (it went up mabye a tiny bit, and very slowly at that).
BTW -- I can say that, on the oil pressure sending unit, where the connector hooks up, there is a little bit of oil that seems to be comming out of the connector.
Any ideas what this could mean/what's causing this [the oil pressure problem]?
Old Sep 8, 2002 | 06:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well if your sender leaks, you already know it's broken. I'd start there... replace it. You may not have a pressure problem at all.
Old Sep 8, 2002 | 06:54 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Re: Low oil pressure...
Been there done that. it the sending unit. i was coming home one day and i notice the oil pressure was a little lower than usual. i was hmm... then i got on the freeway and the pressure stay around 15-20 PSI then i stopped looked at the oil it was full. i found no leaks anywhere. so i drove it home(close to home). i got home and checked the sender there was a little oil on it(by the blade connector). i replaced it and voilia 60 PSI again. replace the sender. good luck
Old Sep 9, 2002 | 09:51 AM
sancho's Avatar
About how much do those bad-boys cost?
Old Sep 9, 2002 | 11:17 PM
Greg Kuhlmann's Avatar
Tops...15 bucks...
I think mine was around 12 or so.
Old Sep 23, 2002 | 09:07 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Transmission: 700R-4
If you've done alot of mods, your oil could be getting hot and breaking down causing the decrease in pressure. That was my problem with my 383. I switched to synthetic and the pressure sky-rocketed.
my86bird
Oct 23, 2015 12:20 PM
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
RyanJB
Sep 2, 2015 01:27 PM
Navy8125
Aug 21, 2015 09:32 AM
