My cat glows red
Old Sep 22, 2002 | 11:01 PM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
My cat glows red
The subject pretty much sums it up. my car has been running a little rich since i put the cat in almost a year ago. but it didn't start glowing until after i put in my cam. i checked my A.I.R. valve and hose. it is injecting air, and the line from the cat does create a slight vacuum, so that part of the cat seams to be working. when i start my car though, i get a lot of moisture from the exhaust, like sprinkles of water, but mixed with carbon. Do you guys think the cat is clogged a bit? a lot of exhaust still comes out, so it doesn't feel clogged by the flow of exhaust.
I HAVEN'T gotten my car tuned yet, but here's what i'm running, just to give more thoughts as to why the cat is glowing red.
-305 TPI w/ 22# inj
-holley AFPR
-World Products Torquer 305 heads
-SLP 1 3/4" Headers
-Borla Exhaust
-3.73's
-Hot Cam
-Catco 3" Catylitic converter
-Vacuum Resevoir
My only real problem as far as better drivability goes is a stock tranny, torque converter, and stock induction, oh, and the prom running in open loop (which i'll have fixed when i get it tuned). Any ideas? Please help. Thanks.
Old Sep 22, 2002 | 11:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
How is your timing? Running lean?
Old Sep 22, 2002 | 11:05 PM
Timing is advanced about 8-10 degrees, it runs its best that way, but like i said, i'll get it completely straightened out once tuned.
Old Sep 23, 2002 | 05:48 PM
MrsLottaBallsCamaro's Avatar
Maybe your cat is just clogged. I had the same thing happen to a Lumina. You couldn't go more than a mile without it glowing bright red.
Old Sep 23, 2002 | 08:04 PM
cdogc350's Avatar
water is a sign of ideal combustion......From what i learned at tech school a couple of years back. i believe the glow might come from a rich mixture burning with the excess air being pumped in the cat
Old Sep 23, 2002 | 09:15 PM
Thanks for the responses guys. I really appreciate it. now i guess its off to get tuned.
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
PurelyPMD
May 5, 2016 04:57 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
andy74
Sep 3, 2015 08:41 AM
