Bent electrode on Sparkplug!!!
Old Sep 10, 2002 | 08:12 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
As the title says......I was running the bird a little harder than usual the other night then WHAMMO...running on seven cylinders. I pulled headers and changed all just for good measure (this has happened before when I had severe detnation..bumped timing down and was fixed) tested it on the road and at WOT it started to detonate and bent it again...Same cyclinder by the way....As long as I drive it like I just bought it, it runs fine.....You guys think I could have jumped timing somehow????? All input on this matter is appreciated!!
Later
Old Sep 11, 2002 | 11:43 AM
Morley's Avatar
Might just be that 1 cylinder running lean. Time to do an injector balance check.
dbrochard
Oct 3, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
RedLeader289
Sep 23, 2015 06:50 AM
TOMcat GTA
Sep 15, 2015 09:31 AM
dbrochard
Sep 7, 2015 09:41 AM
