52mm Throttle Body for 305 TPI
Old Sep 24, 2002 | 10:19 PM
87TA 305TPI's Avatar
right now i have a stock 305 TPI but im building a new 350 for it so i dont want to do anything big to the 305. i was wondering if i put a 52mm throttle body on the 305, if i would see any power gains, im putting an AFPR on it tomorrow and im just trying to get some temporary power so i can make a few bucks. i dont want anything that would be time consming to install because like i said, ill have the 350 soon enough and ill have to take everything off the 305 qanyways. thanks for the help, any other opinions would be appreciated
Russ
xxslayahxx@aol.com
Old Sep 25, 2002 | 03:49 AM
rezinn's Avatar
Spend your money elsewhere. Cold air would do more for you on either engine, as would just about anything of equal price unless you're making a lot of power.
temporary power = nitrous
Old Sep 25, 2002 | 04:36 AM
rockind78's Avatar
IMO, a 52mm. throttle body will do exacltly ZERO for performance on a NA 305. In most cases, a 48mm TB is sufficient for a NA 350. If I were you, I would spend a few more bucks on headers. They should give you some decent power gains, and transfer to your 350 w/o any grief. If I am not mistaken, a BBK throttle body is around $300. Now, I don't know what F-body headers go for (I have a Chevelle), but I wouldn't think it be WHOLE lot more than $300.
Old Sep 25, 2002 | 03:16 PM
bigals87z28's Avatar
Car: Check The Sig
headman-310 + coated
Hooker- 350+ coated
Slp- 500+ coated... all are with AIR tubes, and y pipe... they would be cheaper if u didnt have the air tubes...but i do suggest getting them coated....its worth the money
Old Sep 26, 2002 | 06:10 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
You don't need more than a 48mm TB at all. You have to be making lots of power for that. Spend your money on things that will make a difference. Just get an airfoil for better flow as the engine needs more air.
jhawkeye
May 25, 2022 06:33 PM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
