T-5 questions
Old Dec 24, 2002 | 05:32 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
T-5 questions
Are there any differences in the V-6 and V-8 model, strength, gears, bolting it up to a V-8. If you need more info ask and ill answer, thanks
Kevin
Old Dec 24, 2002 | 06:14 PM
4L60bliss's Avatar
The bellhousing is smaller, since the 2.8/3.1L was a 60° engine.
And if I'm not mistaken, the input shaft is different to accomodate the smaller clutch.
Old Dec 24, 2002 | 06:25 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Yeah, the V6 uses a 14 spline input shaft and the bellhousing is different but it can be replaced with a V8 one.
Also, MOST V6 T5's came with a 4:1 first gear whereas most V8 T5's had first gear around 3:1.
Old Dec 24, 2002 | 07:12 PM
Engine: 383, L69
what about the clutch, can you use a 305 one or do you have to use a v-6 clutch?
Old Dec 24, 2002 | 07:16 PM
4L60bliss's Avatar
Well, if you kept the V6 input shaft, you'd need the V6 clutch, since thats what the input shaft splines too. I wouldn't reccomend that for a V8.
Old Dec 24, 2002 | 08:22 PM
Engine: 383, L69
so would i be better off finding another 5 speed or changing the input shaft?
Old Dec 24, 2002 | 09:40 PM
4L60bliss's Avatar
Yep
Old Dec 24, 2002 | 11:18 PM
Engine: 383, L69
yep what?
Old Dec 24, 2002 | 11:25 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
its not as strong as a V8 T5, BUT you can order a clutch that fits from McLeod OR Summit
ask Summit for the S10 SBC swap T5 clutch
or BETTER yet, order a 14 spline 10 inch clutch disc from McLeod
either way its about $100 which is the cost of a decent clutch anyways
Old Dec 25, 2002 | 07:35 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I have the V-6 T-5 bolted to my 305 and use the V-6 clutch. I haven't had any problems with it slipping, and I have been very hard on it a few times. I will be replacing it with a McLeod when it wears out though.
Old Dec 25, 2002 | 01:53 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
honstly do not waste your money for clutch or inputshaft it is not worth it.(it is really really weak)
sell your tranny t5(v6) and get t5(V8) tranny
Old Dec 25, 2002 | 06:50 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I was told by a couple of people that other than the input shaft that the T-5 from the V-6 and the V-8 are the same. Either way I plan to upgrade the clutch when this one wears out. Now, if/when the T-5 breaks I don't plan on buying another one. It'll be time for an upgrade :hail::hail: T-56
Old Dec 25, 2002 | 07:15 PM
well the gear ratios are WAY different..........most of the internals rearward of the input shaft are the same.......
Old Dec 26, 2002 | 07:29 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
BTW the inputshaft of the V8 wont fit in V6 tranny because teeth of inputshaft gear(V8) are bigger than the hole on V6 housing
Old Dec 26, 2002 | 07:42 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I forgot about the different gear ratios but i think you know what I meant. Does anyone know anything about the Tremec TKO? That is another option I'm looking into if the T-56 isn't feasable at the time.
Old Dec 26, 2002 | 08:00 AM
thats what i was unsure of, thanx for clarifying that for me
Old Dec 26, 2002 | 03:39 PM
84 Challenge's Avatar
Will a t-5 work on an Iron Duke?
Brandon
Old Dec 26, 2002 | 11:49 PM
Engine: 383, L69
sorry it took me so long to reply back, i finally had time to go and check the t-5, it has 10 splines on the input shaft, so is this a v6 or v8 model. thanks
Kevin
Old Dec 27, 2002 | 07:27 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Old Dec 27, 2002 | 07:35 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Kevin
10 splines ?? I think you have Mustang tranny
Old Dec 27, 2002 | 09:02 AM
Brandon
yeah, i belive you need one for a V6 though
Old Dec 27, 2002 | 09:55 AM
Engine: 383, L69
well i was looking in jegs and i can get 10.5 inch 10spline clutchs, listed under chevy cars, but does anyone know what its out of
Old Dec 27, 2002 | 12:25 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Wrong answer.
The non-WC cases are exactly the same for V6 and V8. The input shaft won't fit because the diameter of the 'gear' is different...the V8 piece bieng larger.
I'm using my 83 SC's original V6 case with all the 84 Z28's V8 internals stuffed into it, reasoning that the V6 case hadn't seen the amount of abuse the V8 case had, and hadn't 'stretched'. 2½ years now with no problems...
Pete
Old Dec 27, 2002 | 05:37 PM
Engine: 383, L69
does anyone know anything about the 10 spline input shaft, or whats it out of, or know someone who would know
Old Dec 28, 2002 | 08:44 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Originally posted by Petes 84Z28
Wrong answer.
I was right that what I said
Old Dec 28, 2002 | 09:09 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
in answer to the iron duke question, yes they came with t-5's behind them, you could technically use any gm t-5 with the proper clutch set up, for minimum stress and trouble use a v6 or 4cyl t5 they have a 14 spline input shaft.
as far as reliability with the 4 banger and v6 trannies goes, i ain't havin no trouble but i got no traction either, hense the slow time listed in sig. i chirped 4th gear for cryin out loud,
putting the v6 or 4 banger trans on a v8,
get the right bellhousing, then call up mcleod
www.mcleodind.com (i think thats it)
look through their online catalog first its on about page 6-7 you'll find what you need i got the 200 series disk myself just under $90 shipped to my door
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Cacike
Aug 27, 2015 05:10 PM
redmaroz
Aug 16, 2015 11:40 PM
