How do you adjust 9 bolt axle end play?
Old Dec 28, 2002 | 02:07 PM
SIMON HOLTBY's Avatar
I got a clunking sound from the left rear wheel and after jacking the wheel found there was a lot of play in it. I have just fitted new wheel bearings on both sides and a lot of the play has gone and handling is much better, but when I hit a fairly bad bump in the road there is still a clunk from the rear left.
I jacked the car again and there is I think too much play still. The bearings are tapered roller ones and I cant figure what is pushing the inner part of the bearing into the outer shell to take up any play. You know, like how you adjust a front wheel bearing ie tighten center bolt till play has gone. There is no center bolt to tighten.
Now I didnt change the oil seals as I couldnt get them here in England and its got me thinking. When you tighten the 4 bolts at the end of the axle tube that holds the bearing in it presses on the oil seal which inturn presses on a spacer ring that presses on the rollers. Perhaps my old oil seals are a bit worn and the bearing is not being held tight enough. I plan on making a ring to fit over the oil seal so when I tighten the 4 bolts it squashes the bearing tighter.
What do you think? Any other ideas?
Thanks guys and all the best for the new year!
Simon
88 5.7 IROC
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
