Check Out My Plan
Old Dec 27, 2002 | 12:44 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Check Out My Plan
Here is what I have on TAP for the SBC 400 thats still in the planning phase. I'm thinking about 500hp-500tq. I there is something that you think that needs to be done that can improve my engine feel free to do so. This will be in my 84 Camaro high performance street car that might see the track 6x a year.
My SBC 400
Engine:406 SBC ID# 330817/14y139664/ T0508CSU
(4.155 bore X 3.750 stroke)
Crank: Scat Cast 9000 3.750 6.00, Internally Balance
Piston Wiseco Pistons .030, 5.4cc - 10.45:1cr;
Rods: Eagle SIR 4340 H-Rods 6.0
Block: Zero Deck: 00.0000
Cam: Grind: XE274H-10, Duration @.050: 230IN / 236 EX, Adv. Duration 274 IN-286 EX, Valve Lift: 487 IN – 490 EX, LSA110*. Intake Centerline: 106*, RPM Range: 1800-6000; Roller Setup, or Ultradye Solid (SB280/288F10, 247/255 @ .050, .525"/.540" valve lift, 110 LSA, 104 ICL)
Heads: AFR 195 23º valve angle, 74cc, drilled steam holes
Head Gasket: Fel-Pro-1014 / 0.039
Intake: Edelbrock RPM #7101
Carb: Holley Street Avenger 770 or 750 (3310)
Rear End Gear: 3:73
Transmission: Pro-Built Street/Strip 700R4
Stall Converter: A.C.T. 3000 s.s.
Just remember I want to keep this streetable but still have awesome power from 2000-5500 RPM.
Thanks for all the knowlege and suggestion..
David
Old Dec 27, 2002 | 12:55 PM
385LT1's Avatar
Displacement: 412.67
compression: 10.58:1
compression ratio calculator
Dont ya think that Holley 750 will be a tad bit too small?
Especially with a 110 LSA and 412 cubes...
just a thought
BTW- what do the AFR heads flow? or are they untouched from AFR?
Old Dec 27, 2002 | 01:12 PM
DTL504's Avatar
Displacement is a 406, you thinking a .060 over block will give you a 412cu. I'm going .030 over.
Bore 4.155 Stroke: 3.750= 406 cu
ENTER YOUR DATA calculated data
Cylinder Head Volume (cc) 74 Cylinder Head Vol (cubic in.) 04.514
Piston Head Volume (cc) 5.4 Piston Head Vol (cubic in.) 00.329
Gasket Thickness (in.) .039 Swept Volume (cubic in.) 50.847
Gasket Bore (in.) 4.200 T.D.C. Volume (cubic in.) 05.384
Cylinder Bore Diameter (in.)4.155 Gasket Volume (cubic in.) 00.540
Deck Clearance (in.) Note: Neg. nubmer above deck, Pos. number below deck Deck Volume (cubic in.) 00.000
Stroke (in.) 3.750
COMPRESSION RATIO 10.445
This will be a 406 and dont know how you came up with the 412..
Here try this:
http://www.kb-silvolite.com/calc.phtml
Old Dec 27, 2002 | 02:20 PM
385LT1's Avatar
Stroke (in.) 3.750
Here try this:
4.155 before or after the 0.030" pistons?
if after..... then add 0.030" too that........ 406.77 cid + .030" = 412
You didnt specify.....wether your current displacement included the 30 over pistons or not.......
Old Dec 27, 2002 | 02:50 PM
DTL504's Avatar
Re: Check Out My Plan
My SBC 400
Rear End Gear: 3:73
David
Old Dec 27, 2002 | 05:23 PM
385LT1's Avatar
AND.....
IF YOU DIDNT WANT ANY HELP IN THE FIRST PLACE , WHY DID YOU MAKE THE POST.......
AussiePr0nCar
Mar 6, 2020 04:04 PM
italiano67
Dec 11, 2016 09:21 AM
fbirdroller
Sep 2, 2015 10:27 PM
someone972
Aug 30, 2015 12:52 AM
gwade12
Aug 8, 2015 08:17 AM
