Need help with valve covers
Old Jan 28, 2003 | 05:29 AM
87IROC350's Avatar
Engine: 5.7
End of last year I read an article that was mentioned new centerbolt tall valve covers that were made by GM. I am having problems finding the article for the part numbers.
Can anyone help?
Old Jan 28, 2003 | 01:32 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
yep
they are made by proform for gm
go here https://www.spoperformanceparts.com/...html?CATID=624
Old Jan 28, 2003 | 07:07 PM
87IROC350's Avatar
Engine: 5.7
Nice, it says for Gen I & II engines I assume they will work on ours engines w/ centerbolts.
Anybody tried these or have feedback on the product? Wow a little pricy also $120-$150 on GMparts.com
12497985 12497985 — Cover, Valve Aluminum Chrome Finish (Center Bolt Design)
These die cast aluminum valve covers have a chrome finish. They are used on all 1986 and newer Gen I and 2 engines with center hold down design. They are approximately 1/4 inches taller than production covers.
Technical Notes: Use rocker cover gasket P/N 10046089 and replacement bolt and seal in kit P/N 12497980. (The kit includes two valve covers, eight bolts, washers, and seals.)
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
