STB and Spacers, Safe ???
Old Feb 8, 2003 | 01:06 AM
92GTA's Avatar
I have a brand new 1-piece 3-pt Kenny Brown Strut Tower Brace but since I have SLP runners I had a machine shop custom fab me some solid aluminum spacers to go under the mounts on the strut towers. I used a 1/2 spacer on each side, it fits perfect now and doesn't even touch the hood liner
My questions is, I drive my car REALLY hard through windy mountain roads and I'd like some reassureance that it's safe to use the spacers??? I also went with the strongest bolts I could find. I'm just hoping that a 1/2 inch of aluminum isn't going to put too much strain on the top portion of the bolt and that it will snap going through a turn. I highly doubt it will though being that there are 3 bolts on each mount. I'm right, right?
Old Feb 8, 2003 | 06:59 AM
ede's Avatar
ede
well i didn't run the stress on a computer mock up or anything like that, but i'd say it's fine and you won't have any problems.
Old Feb 8, 2003 | 08:08 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I believe if it's safe to drive without the bar at all, it's probably better even with the spacers than it used to be. Honestly though, I can't see how they could be causing any problems, as long as the hardware (bolts) is adequate.
Old Feb 8, 2003 | 08:22 AM
Z28DJP1987's Avatar
Also had to fab aluminum spacers for my STB to clear the TPI. No problem as long as the fasteners are long enough.
Old Feb 8, 2003 | 10:23 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
92GTA, got any pics? I never see many pics of the kenny brown... if you don't have any pics, do you think if it's not any trouble you could take one or two? Thanks.
Old Feb 8, 2003 | 12:05 PM
92GTA's Avatar
Sure I can snap a few pics. It's off the car right now cause I'm doing some restoration work on the engine comparment, but as soon as I put it back on (monday or tuesday) I'll post some pics.
Old Feb 8, 2003 | 01:58 PM
MdFormula350's Avatar
i also want to see some pics..
Old Feb 11, 2003 | 05:04 PM
Hg's Avatar
Hg
Car: '87 Z
did u happen to get any pics yet???
Old Feb 11, 2003 | 05:09 PM
92GTA's Avatar
No I just picked up the spacers and I need to use a belt sander to get the correct angle on them.
I should get that done in the next 48 hours.
I will however run to my garage right now and take a picture for you as it is, hold on.....
Old Feb 11, 2003 | 05:35 PM
92GTA's Avatar
Here you go:
And this is what I mean by sanding down the space to get the correct angle:
Old Feb 11, 2003 | 05:39 PM
92GTA's Avatar
Now keep in mind that where it bolts to the Firewall, there is 1 big bar of metal that attaches to the 2 bars that go to the firewall and is very sturdy. The entire piece is 1 big piece with NO joints, that's my kind of brace. However I would buy a Spohn brace but ONLY if it's 1 piece. I mean think about, you use it for regidity, why put a joint in it right...
If you want I can also take a picture of just the brace out of the car but that will have to wait til tomorrow if you want it...
Old Feb 11, 2003 | 05:48 PM
Z28DJP1987's Avatar
I think the Hotchkis Looks better and does the job.
Old Feb 11, 2003 | 05:53 PM
92GTA's Avatar
I guess if you want some big red out of place looking thing in your engine compartment, plus it has joints. If it was black and 1 piece I'd agree...
The Kenny Brown is painted and texured so well, it looks like a factory piece. It blends in perfectly. I love it...
Old Feb 11, 2003 | 06:17 PM
Hg's Avatar
Hg
Car: '87 Z
d@mn dude, you needed a huge spacer. Is there one for each side or did you just make one for that side? Is the rear point like offset or is it just an optical illusion with how the engine sits? I kinda like the look of the hotchkis better, but like you said, it seems to me the kenny brown would work just that much better. And I know the descretion of it on your car is exactly what you want, your car being so stock and low miles and all, but I'm going to have all spohn suspenion and I want a red powder coated brace to match the suspension... oh yeah, my car is red too, lol.
Old Feb 11, 2003 | 06:24 PM
92GTA's Avatar
I have a couple Spohn parts too but I ordered those black on purpose as well. Yes it sits a little off center purpose so it fits better. BTW, my GTA has 103K miles, not exactly low milage
I only have the spacer on that 1 side. The other side didn't need one and with the spacer on the one side, it STB actually sits perfectly straight now. I can't explain it but it does. My front has never been wrecked either. Without the spacer it cleared the passenger side top of the plenum but it was on a downward angle toward the drivers side and it touched the drivers side top of the plenum wihout the spacer. I took the STB in to be bent alittle but we decided it would put a kink in the tubing and compramise the stregnth...
Old Feb 11, 2003 | 07:38 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
92GTA~ How does that STB attach to the firewall?? You dont run self-tapping screws into the firewall do you??
Later..
Dan
Old Feb 11, 2003 | 07:44 PM
92GTA's Avatar
No, you use a 3/8 drill bit and an electric drill. There is just one hole. Talk about a MAJOR BITCH though!!! That metal is thick and hard as HELL.
Old Feb 11, 2003 | 09:18 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
if you use a smaller bit 1st to drill a pilot its really not too bad..... i really dont know why so many people buy the hotchkis STB personally, it sticks out, is more expensive, and is only 2 points. i have an edelbrock, but that kenny brown looks great.... how much u pay for it?
Old Feb 11, 2003 | 09:23 PM
92GTA's Avatar
It was only like $135 or something, hella cheap I thought.
I did use a smaller bit to get all ofthe holes started but even with that it was still pretty hard. The metal is ALLOT thicker and stronger than I thought. Knowing that I am VERY glad I got the 3-pt instead of the 2-pt...
I almost got the Edelbrock but at the last minute decided on the Kenny Brown...
Old Feb 11, 2003 | 09:39 PM
bigals87z28's Avatar
Car: Check The Sig
is the 3pt really that much better the a 2pt one?
Old Feb 11, 2003 | 09:45 PM
92GTA's Avatar
Only if it's an Edelbrock or a Kenny Brown
People like to argue that point but if it's a solid 1 piece like the KB then of course it would be, IMO anyway...
Old Feb 13, 2003 | 08:18 PM
92GTA's Avatar
I just finished having my spacer machined. I put an angle on the top and shaved an 1/8th inch off the bottom. If you care to see the final fit an finish just let me know and I'll post a pic. I came out totally sweet. It blends in really well, you don't even notice it really unless it's pointed out...
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
