Tell me about your gauge cluster!
Old Mar 15, 2003 | 09:43 PM
88txiroc's Avatar
Ok,
Here is the deal. Alloy and I are trying to get a business to make some new gauges for us. We are trying to get gauges for the 145 mph speedo.
If you have a 145 speedo in your car from the factory, can you please post what year it is? We really want to get this done. Someone already has the 91-92 clusters done, so we need to work on the earlier years.
Please try to stay on topic. No flames or negative posts. If you have questions or comments, please post. Thanks for your help.
I will start with my car.
1988 Camaro IROC Z. 145 speedo with the 5500 redline.
Old Mar 15, 2003 | 11:21 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
I have an 86 Sport Coupe that has a 240 kmh speedo and a 5500 rpm redline gauge set that came from Stephen87Iroc's 87 Iroc.
Old Mar 16, 2003 | 12:33 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
1989 Camaro IROC-Z L98, 145 MPH Speedo and 5500 redline
Old Mar 16, 2003 | 02:14 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
87 iroc 145 mph speedo, 5500 redline tach.
MetalliCamaroRS -is this the same style cluster you have?
Here is a pic of the style cluster we are referring to. We know it fits 87 and 88, and I beleive 86. If you have more info on what years this style cluster fits, please post here.
Also, if you have a spare cluster like this that you can send in for a sample to the company that will be making these, please contact myself or Thomas "88aziroc" Otherwise I'll be looking for one on Ebay to use as a sample.
Old Mar 16, 2003 | 01:24 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
My 85 and 86 had the same 145mph speedo as my 87, don't know if they were factory though...
I can't commit to buy any as I'm flat broke, but both me and my brother would likely buy a set at some point if they make them...
Old Mar 16, 2003 | 01:26 PM
The_Prostitute's Avatar
If anyone is looking for reverse style gauges for the following vehicle models:
1990–1992 Chevy Camaro RS 120 MPH
1990–1992 Chevy Camaro IROC Z-28 140 MPH
Please refer to the following post...
https://www.thirdgen.org/techbb2/sho...hreadid=166399
Old Mar 16, 2003 | 01:49 PM
alloy's Avatar
Car: 87 IROC-Z28
Ray87z,
If you 85 had this style, then is was probably factory. So now we know the same stlye fits 85 to 89. I doubt if it fits an 84. From what I see in the wrecking yards the 84 and earlier were quite different from my 87.
I'm glad to see we have both of these threads on indiglo gauges cross linked to each other now. That way we cover all years of cars.
Old Mar 16, 2003 | 01:55 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
used to have the stock 90 irocz 145 cluster (sold it, but its practically the same for 91-92)
Now i have a stock 98 z28 cluster in place, 155mph, dunno if im going to keep it or send it in to get the 200mph one, because that would be just plain sweet!
Old Mar 16, 2003 | 04:07 PM
Engine: 305-4v
Originally posted by alloy
Ray87z,
No, they never came onb 1985 Camaros. The 145 mph (or 240 kmh) speedos only started to be installed at the factory late in 1986.
Old Mar 16, 2003 | 04:45 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
I can confirm that my car is a 1985 Camaro Z28, and only has the 85mph speedo.
Old Mar 16, 2003 | 05:34 PM
CW Racing's Avatar
My speedo only goes to 115 and the redline begins at 5000 like the one in the pic alloy posted. What do I need to do to use the 145 and make it accurate? Is it an easy thing? I hope so because I would really like to get in on this purchase.
Old Mar 16, 2003 | 06:36 PM
alloy's Avatar
Car: 87 IROC-Z28
Ok, we have established that the 145 speedo fit 86-87-88-and 89. I'll send that info to the company with the overlays.
Cw racing,
You will have to replace the speedo with a 145 unit. As far as I know, you can't just replace the guage face and have the speedo read correctly.
You might call a speedo shop and ask them. They might have a trick or something they can do to your speedo to re-calibrate it or something like that.
If we go ahead with this, I'll have an extra 145 speedo. I have to buy one to send in, and it will be returned to me after the overlays are done. They have to remove the needles, so the speedo might be off a tick or two but that's easily fixable. I'll put the new overlays on the existing cluster I already have in the car. They told me to install the overlays you do not need to remove the needles, so I'll just do it that way and keep my odometer reading correct.
So if you want the second cluster, sign up and we will see where this goes.
Old Mar 16, 2003 | 08:39 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
i have a 83 Z28 w/ 85 mph and the other half is kph. then my 87 formula is 140mph, but thats getting reverse indiglows.
Old Mar 16, 2003 | 09:10 PM
CW Racing's Avatar
I'll go in on this. When will the streetraceparts page have a link for us to buy in?
Old Mar 16, 2003 | 10:51 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
88 Camaro Iroc-Z 145 speedo 5500 redline
Old Mar 17, 2003 | 01:43 AM
alloy's Avatar
Car: 87 IROC-Z28
Well here is a link to where the sign up page will be when we get enough people here to commit to buying a set of these. We need ten people to commit here before moving forward on this.
http://www.streetracerparts.com/reverse_style.htm
When we get ten people here that will commit to this, I'll send in a cluster and you can go and sign up for a set.
Old Mar 17, 2003 | 06:44 AM
zed's Avatar
zed
Car: 1991 Z28, 1984 Z28, 1990 Toyota 4x4
Engine: L98, L69, 22RE
Transmission: 700R4, 700R4, 5Speed Manual
Axle/Gears: 3.73, 3.23 Posi, 4.10
buy in
there's no listing for '80s camaro's there, just 90-92.
Old Mar 17, 2003 | 09:59 AM
alloy's Avatar
Car: 87 IROC-Z28
That's right. We need 10 people here to commit before we ask them to list the 86 to 89 camaro.
Old Mar 17, 2003 | 12:16 PM
88txiroc's Avatar
So, if you want these to go into development, we need 10 people to say "Go" and the company will start to make them. It will take about 3-4 weeks for them to tool up for it, then they will send them out. Thinking about 5 weeks, once we get 10 confirmed orders.
When we get 10, Alloy or myself will get the ball rolling. Then we will get them to put a buy-in spot for our cars.
After that, you will need to go to the website and put in your order. They will ask for your credit card, but it WILL NOT be charged until 10 sign up. That will start the approx. 5 week period for tooling and shipment.
So far we have:
1. 88aziroc
2. alloy
3. CW racing
4. 5SIZ
5. Zed
6. 88Roc350TPI
7. Wootah
8. aaron7
9. cayse
10.
Only one more to go and we can go into development!!!
If you want added to this list, and you are going to order FOR SURE, post or PM alloy or myself.
Old Mar 17, 2003 | 05:02 PM
5SIZ's Avatar
Car: 1987 IROC-Z
of course you can count me in on this deal Tom, add me to your list dude.
P.S. I am adding a link ot this thread at another site I moderate, we should get some more people from there
Old Mar 17, 2003 | 11:24 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
89 iroc
came with a 185 km/h speedo, i swapped in a 145mph one works fine.
When is the deadline here? i have absolutly no income but i really want a set of these gauges. if you can hold out a couple of months i may be able to get the cash...
Old Mar 17, 2003 | 11:27 PM
5SIZ's Avatar
Car: 1987 IROC-Z
sorry buddy but if we do this I want it to be A.S.A.P.
Old Mar 18, 2003 | 12:02 AM
zed's Avatar
zed
put me down for a set.
Old Mar 19, 2003 | 07:56 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
1988 Iroc, LB9 5.0 TPI 220hp 290ftlb, I have the 140mph with Z28 on the bottom of the guage. I also have the 5500 redline tach.
Old Mar 19, 2003 | 11:38 AM
88Roc350TPI's Avatar
I'll take a set
'88 IROC, 145speedo, 5500 redline
Old Mar 19, 2003 | 11:39 AM
5SIZ's Avatar
Car: 1987 IROC-Z
6 down, 4 more to go!
Old Mar 19, 2003 | 11:49 AM
Hey guys,
JUST FOUND THIS!!! Maybe we don't need to get them to tool up!!!
http://cgi.ebay.com/ebaymotors/ws/eB...category=33678
Old Mar 19, 2003 | 11:53 AM
5SIZ's Avatar
Car: 1987 IROC-Z
i would rather get the reverse gauges, they look so much cooler.
Old Mar 19, 2003 | 12:02 PM
alloy's Avatar
Car: 87 IROC-Z28
I agree. I want the reverse style also.
Old Mar 19, 2003 | 12:15 PM
88txiroc's Avatar
Originally posted by 88Roc350TPI
Hey guys,
:nono: :nono: :nono:
Just look at his feedback. Dont want to deal with that guy.
Lets face it, the reverse gauges look WAY better, anyway.
Old Mar 19, 2003 | 12:57 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Who made those anyway though, surely he didn't make them himself?
Old Mar 19, 2003 | 03:52 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Dang! What about us T/A guys?
Mine is an '86 T/A with the 140 speedo, but I forget what it redlines at. Currently supporting OEF, so I can't look!
I would like to get a set and would definately step in for some. (Need to spend this money somewhere else besides this ship )
Any plans for the T/A's?
Old Mar 20, 2003 | 10:26 PM
Hey,
Sorry about my post above. I thought you all were referring to the Indiglo type gauges, not the reverse backlit ones. I'd prefer the reverse ones over the indiglos too so put me down, If they don't get them rolling soon though I'll have to do something else.
Old Mar 20, 2003 | 11:03 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
how much would the gauges cost? if theyre not too expensive i may go for it. let me know kids
Old Mar 20, 2003 | 11:42 PM
alloy's Avatar
Car: 87 IROC-Z28
I haven't been quoted the exact price, but all the other set of reverse ovelays on their site are $69.99. So I don't see why these would be any more expensive than the others.
Old Mar 21, 2003 | 07:04 AM
88txiroc's Avatar
Jim, look at the thread that is referenced at the top of this one. IIRC there is already someone making reverse style gauges for your car. They look really nice, too. HTH. Thomas
Old Mar 21, 2003 | 07:08 AM
CrazyHawaiian's Avatar
Car: too many ...
I dont want any overlays or anything, but heres what I got
1990 RS - 115 mph cluster, forget the redline (5000?)
1990 IROC (now in RS) - 145 mph cluster, redline 5500
1991 Z28 - 145 mph cluster, redline 5500
Old Mar 21, 2003 | 11:47 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
add me to the list for sure 88 Iroc-Z 145mph 5500 red
Old Mar 22, 2003 | 09:34 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
As long as they don't cost more than $70-80, count me in!
Old Mar 22, 2003 | 09:40 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Old Mar 23, 2003 | 12:08 AM
alloy's Avatar
Car: 87 IROC-Z28
I just re-read the email the company sent to me and the price is $69.99 plus $8 for shipping. Total of $77.99 This price is confirmed.
Old Mar 23, 2003 | 10:07 AM
CaysE's Avatar
I definitely want a set of these, but I have the 85mph speedo. Can someone point me in the direction of converting my cluster into a 145? All the other gauges are exactly like mine.
Old Mar 23, 2003 | 10:59 AM
alloy's Avatar
Car: 87 IROC-Z28
CaysE, The only direction to point you is your local wrecking yard, the TGO classifieds, or Ebay. You speedo can't be converted, it needs to be replaced with a 145 speedo.
Old Mar 23, 2003 | 11:29 AM
88txiroc's Avatar
Casey,
There are about 10 different 145 mph clusters on eBay right now. They are going for about $100. Kinda steep, but you get the whole cluster.
PM alloy and talk to him about the cluster we are going to get for the development. We could probably sell that to you once the gauges are finished. I am not sure if he has someone lined up already or not. We have to send one in, and no one has a spare they want to use. Alloy and I have planned on buying one to send in, but then we would have an extra one. Mine is perfect, so I wont need it. I dont mind pitching in to get it now, as long as someone wants to buy it after.
COME ON GUYS!!! WE ONLY NEED TWO MORE TO GET THIS STARTED!!!
Old Mar 23, 2003 | 05:11 PM
CaysE's Avatar
I'll take the extra cluster, if noone else has offered. If I get the 145 cluster, is there anything else I need to change on the car so that it reads correctly?
Hell, preinstall the gauges for me and I'll throw in a little extra.
Old Mar 23, 2003 | 06:04 PM
alloy's Avatar
Car: 87 IROC-Z28
CaysE,
The cluster has already been spoken for when I get one. But there are lots of them on ebay, and at least two in the TGO classified section. The one lady would sell the one she had for $70.
There is nothing you have to change to make the 145 speedo read correctly on your car other than the speedo itself. The rest of the cluster is the same with the speedo being the only part that is different.
We are in kind of a hurry to get a spare cluster so we can get these started ASAP. But after we get the sample cluster in to the company making these, you will have about 4 weeks to find a cluster for your car before the overlays are ready. 88aziroc said he saw then go for as little as $50 on ebay, so if you bide your time, you might get lucky.
So in the mean time, please sign up for a set of the overlays.
Old Mar 23, 2003 | 09:00 PM
CaysE's Avatar
OK, guys... sign me up.
CrazyHawaiian... what springs do you have on your car in the picture? it has a nice stance.
Old Mar 24, 2003 | 06:55 AM
CaysE's Avatar
alloy, PM JerseyIrocZ... he showed interest in the 90-92 gauge post for his 89, but hasn't signed up yet.
nice sig pic, wootah
Old Mar 24, 2003 | 10:52 AM
alloy's Avatar
Car: 87 IROC-Z28
I just pm'd JerseyIrocZ about the overlays. I also just paid $86.36 for a gauge cluster. Hopefully the seller will ship it ASAP.
So now we just need one more person to step up and we can get this show on the road!
Old Mar 24, 2003 | 08:42 PM
5SIZ's Avatar
Car: 1987 IROC-Z
super sweeeet..
