My Planned Mods...worth it?
Hey guys, I've been reading messages on these boards pretty much everynight, and feel that I've gained more knowledge than what i started out with. i want to do some mods to my car, that improve acceleration...basically i just wanna burn rubber when i floor it, i'm not too concerned about top speed, i don't plan on going 120mph in this car. i've found a website that helped me out a lot, and i compiled information from that site to help me in my process....what do you gusy think..are these mods worth it to get the results i'm looking for, or can i do less mods, get better results, at the same price ($1500 max.) Thanks always for your help.
TBI Mods
Modification: Item Name: Part Number: Location: Price:
Exhaust:
High Flow Cat: Dynomax Super Converter (2-way) 3"-18"long #289-15147 http://www.jegs.com/cgi-bin/ncommerc...92&prmenbr=361$139.99
Ignition:
Spark Plug Wires: MSD 8.5mm Superconducter w/ 90° boots #MSD-31229 http://store.summitracing.com/partdetail.asp?part=7426 $69.95
Ignition Coil: MSD Blaster Coil #MSD-8226 http://store.summitracing.com/partdetail.asp?part=9030 $38.95
Cap: MSD #MSD-8426 http://store.summitracing.com/partdetail.asp?part=8898 $21.39
Rotor: MSD #MSD-8427 http://store.summitracing.com/partdetail.asp?part=24236 $6.99
Spark Plugs: AC Delco RAPIDFIRE (.045" gap) #CR45TS
Rear End:
Gears: GM Motive 3:42's N/A http://www.gearsareus.com/_private/G...ff/gearsgm.htm$170
Differential: Auburn GM 7-1/2'' & 7-5/8'' 10-Bolt, 26-Spline 109-542057 http://www.jegs.com/cgi-bin/ncommerc...20&prmenbr=361$329.99
Engine:
Air Filter: K&N 14 x 3 Open Element Assembly & Element KNN-60-1264 http://store.summitracing.com/partde...sp?part=779 or Autozone
Thermostat: 160° Hypertech Thermostat HYP-1000 http://store.summitracing.com/partdetail.asp?part=10376 $7.39
Computer Chip: Hypertech Thermomaster HYP-128962 http://store.summitracing.com/partdetail.asp?part=20774 $121.95
TBI Spacer: .5" Spacer #635-500 http://www.turbocity.com/TBIPowerMain.htm $42.95
Injector Spacer: TBI Spacer #630-105 http://www.turbocity.com/TBIPowerMain.htm $19.95
AFPR: Adjustable Fuel Pressure Regulator 9-13psi #630-130 http://www.turbocity.com/TBIPowerMain.htm $69.95
Fan Switch: Hypertech Cool Fan Switch #4026 http://store.summitracing.com/partdetail.asp?part=10421 $42.95
Approx. Total Price: $1,082.40
excl. Tax & Shipping
TBI Mods
Exhaust:
Ignition:
Rear End:
Engine:
Car: 2002 Z28
for the same price of the auburn posi, you can probably get some 28 spline axles and an SLP take off posi, just another option to throw in there. search "slp posi" if you want more info.
i wouldnt ONLY do the cat, do the whole exhaust or do nothing, unbottlenecking only the middle part isnt gonna help a whole lot
the ignition stuff is good for a tune up but not gonna give you a substantial power increase
get the slp posi instead like he said, 100 bucks
lots of people say the chips are crap but personally i noticed a huge difference, i dont think its a bad idea
you'll need an installation kit with new bearings and gaskets for the rear end. that's $100.
the gears are your best mod on that list, then you should do FULL exhaust from headers on back. then the ultimate tbi, the spacers, and open element. those things will help you more than everything else put together.
Originally posted by tbfirebird
why not somehting in the 4.?? or better yet 5.??
Car: 2002 Z28
come on now, 5.xx gear ratio, i hope you are joking around. Also, try ebay for some of the stuff, tntperformance sells turbocity TBI spacers for 30 and their injector spacers for only 15. You can also make your fuel pressure regulator adjustable for free and it will be exactly the same as the turbocity version.
also www.tbichips.com sells some tbi performance chips for only 30 bucks, you might want to check them out before decided to spend over 120 for the hypertech one.
vjo90RS8: if it's for the same price, why would I do that, is the 28 spline better than the 26, how so? thanks for the cheaper chip, is there a performance difference between the 2 chips?
tbfirebird: thanx for the advice, i'm a bit wearie of the auction stuff, but we'll see
v8unleashed: I already have flowmaster exhaust, since i'm on a tight budget, would i see more gain with upgrading the cat or adding new headers? how is the slp posi better when i would have to replace the axle as well to a 28 spline?
does anyone see anything on the list that i should take it cause it won't help at all? thanks again everyone for your input
Engine: LO3;383tpi
Do not waste your money on the hypertech chip. Until you get winaldl data, don't even worry about a chip. After you get data, go to tbichips.com and brian will hook you up.
definetely go with at least a cat back system, but perferably headers and y-pipe. Spend the extra $$ and get the headers ceramic coated-it's worth it.
If I remember right, some '89s came with 28 spline axels-you would have to check your VIN to find out, though I'm not sure at which point they changed. The SLP unit works great btw.
Instead of buying stuff from turbocity, use the money and buy an intake manifold. Depending on what your overall plans are will determine what intake to go with. Perform the ultimate tbi mods and go from there. Look into Turbocity stuff after you have your engine breathing and performing better.
As far as ignition goes, it's nice but not needed until you do your other mods first. The msd coil works really well, especially with the msd 6A, but it's not needed until you get your engine breathing past 4,500-5,000rpm.
I would also suggest underdrive pulleys if you can find them for cheap. But at full price they're not really a great mod. If you have an automatic, shift kits are really nice especially with 3.73s. If your lookin at turning tires, then you will really love the shift into second. If you have a standard, think about a short throw shifter. Best of luck with your project
TBI Mods
Good Idea, its easy to do
High Flow Cat: Dynomax Super Converter (2-way) 3"-18"long #289-15147 http://www.jegs.com/cgi-bin/ncommer...92&prmenbr=361 $139.99
get a catco if you are gonna use a cat
you are also gonna need headers and a catback exhaust
Ignition:
Dont worry about it yet
Ignition doesnt =hp in my book
Rear End:
Gears: GM Motive 3:42's N/A Gears
Get them off ebay or classified's here
get the slp posi carrier as well
Engine:
Air Filter: K&N 14 x 3 Open Element Assembly & Element KNN-60-1264 http://store.summitracing.com/partd...asp?part=779 or Autozone
Thermostat:
I wouldnt buy into a hyptertech thermostat
Computer Chip: Hypertech Thermomaster HYP-128962 http://store.summitracing.com/partd...asp?part=20774 $121.95
Wait off on a chip its not really worth it, advancing your timing is more effective.
Make your own spacers
this mod is a pain i havent done it yet
if you have time modify ur stock one.
Fan Switch: Hypertech Cool Fan Switch #4026 http://store.summitracing.com/partd...asp?part=10421 $42.95
the fan switch is a good idea
you really need to get a cam tho, the lt1 cam is good if your on a budget.
I would also recommend you get rid of the stock heads, they arent that great.
the whole exhaust system does need to be replaced, the stock manifolds arent to good at all.
dont forget the edelbrock performer tbi intake manifold
Ignition:
Rear End:
Engine:
Thermostat:
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I'd say the 2 most important things are headers/exhaust and gears/posi. I don't think anyone is in the 14s without those mods. Some money savers are:
If you want to burn tires, don't get any suspension mods, suspension usually helps traction and acceleration. (I assume you meant you want to go fast instead of burn tires.)
Air filter $40-60 K&N etc. Open element. (I'd stay with a snorkle setup)
Headers with 3" y-pipe $320 edelbrock, $$cheaper for others.
catco cat should be ~$70 for a universal slip fit 3"
T-stat autozone/advance auto ~$3-5
Cooling fan switch autozone/Advance auto $8-17 (this will be under certain corvette part numbers) I got one for a '91 corvette for $7.50, but I'm not certain if it's the 200* on 185* off yet.
28 spline axles will be stronger than the 26. Get 3.73 gears perfect for the track 1:1 ratio and 3.73s = ~100mph @ 5000 rpm. Gears/posi = ~$500 with install.
If it's auto. get a torque converter, it'll help a lot so I hear, wouldn't know personally though.
Skip on the wires,cap, rotor, and coil unless you are having some problems already, They are a good idea if you have an extra $100 to spend, but you already said you're on a budget and they won't help going fast.
That's about a grand w/o torque converter and should get you to low 15's/high 14's.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I have a '90 305 TBI LO3 engine - I paid $500 for the car - I'm like you ... not looking for 120+ MPH, just some fun - and I've been reading here for about 6 months and learning as well. I'm also bound by emissions - here's my plan thus far:
Homemade dual snorkel setup - $25 DONE
- felt this mod right off the bat
K&N Filter $40 new
Ultimate TBI mods FREE
Weiand Action Plus #8000 Intake - has EGR $120 new
Headers/3" catback with hi-flow cat/muffler (brand yet undecided) $400-$500 new
Catco Cat $100 new
LT1 Cam $40 used
1.6 Roller-tip Rockers $100 new
Vette Tranny Servo $25 online
Heads - casting #416 from a parts car I bought - ported/polished, 1.94/1.60 valves - I'm doing the porting (it's a learning experience) - these heads are usually gotten used pretty cheap, and they flow well - check Sitting Bull's article - about $250 in machine shop work, $75 for grinder & bits, and my precious time
Rear - Planned on a used 3.42 Posi - came across a complete drum to drum 3.08 posi cheap ($100) with 24mm sway bar, so it will have to do for now (I'm a tighta$$) - installing this weekend
Prothane bushings all around $140 new
Just redid front brakes - everything EXCEPT calipers - $120 new
(what an improvement!)
Wonderbar $50 new
New Panhard Bar $75 new
New Frt Sway Bar $100
Chip Mods $???
This list totals about $1900 give or take before chip mods. I've scavenged some parts online at good deals - hoping to scavenge some more. There's always the unexpected expenses. And I expect to have to do some new ignition stuff, as well maybe more tranny work. But, it all takes time, I'm in no big hurry, and I spend (or save) a little each paycheck, do my own work (what I can), and learn tons along the way. It also gives me something to do, and I have something accomplished in the end that I can say "I did it" - isn't that the point?
If you are a 1989 - you may have 28 spline axles already - have to actually look at axles to tell - I understand they went to 28 spline in mid 89. My '90 has 28 spline, but no posi and 2.73 gears.
PM me - I'll be happy to expand on anything.
K&N Filter $40 new
Catco Cat $100 new
LT1 Cam $40 used
Wonderbar $50 new
Chip Mods $???
