Fix the exhaust leak or get headers?
Old Jun 19, 2003 | 07:17 AM
Camaro89's Avatar
I recently just rebuilt my 350 engine for my 88 IROC. No frills were put into the engine - it was rebuilt stock. I had an exhaust leak before pulling the engine between the Ypipe and exhaust manifolds. I searched the forums and much to my dismay it appears there is no gasket to replace between the the exhaust manifold and Ypipe. From what I read, its just tightening up the bolts as much as possible but I am afraid the bolts on my exhaust manifolds will break or the threads will be ruined - they are pretty corroded. In the event of this happening, which headers would be best for a stock 350 engine? I was thinking the Hooker 2055s since a 1 3/4" primaries wouldn't be a noticeable improvement over 1 5/8" primaries on a stock 350? Any thoughts on headers or fixing the current exhaust leak? Thanks
Old Jun 19, 2003 | 08:09 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You don't need 1 3/4 headers till you're over 400 hp or so.
I'd go with the Hooker 2055s, just be sure to get stage 8 locking bolts.
Old Jun 19, 2003 | 08:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If all you're worried about is the bolts from y-pipe to manifolds breaking, replace the bolts (studs).
Old Jun 19, 2003 | 09:13 AM
Camaro89's Avatar
How easy is it to replace the studs? You have to drill them out right?
Old Jun 19, 2003 | 10:42 AM
five7kid's Avatar
Not if they aren't broken already. Penetrating oil, heat, work them out. Install new.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bamaboy0323
Sep 3, 2015 06:07 AM
IROCThe5.7L
DIY PROM
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
