Carb for L69
Old Jul 4, 2003 | 10:31 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Carb for L69
What would be a good, non computer crap carbureator? I need one easy to tune, and make some power. MPG is important. I want to do some bolt-ons like some exhaust on my high output. A carb would seem to help. If I got one, what would be a good cfm, seeing ppl run 600, when the stock is 650cfm quadrajet four barrel?
Old Jul 4, 2003 | 10:39 PM
jeffs82z28's Avatar
Find a non-cc Q-jet.
Excellent mileage potential, if you can keep your foot out of it and the ability to flow enough air for any reasonable street motor.
Old Jul 5, 2003 | 12:10 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You could also go with a 600cfm holley 4160. It'll pull down decent gas mileage, and flow plenty when you get on it.
Old Jul 5, 2003 | 10:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'll break ranks here and say you've already got the best possible carb for your goals. A non-CC q-jet will not get as good of mileage as the CC one will, assuming both are properly set up. The CC carb has all the power potential that the non-CC carbs have. The cost to convert will blow a lot of gas money. The CC-carb will adjust to other power improvements just fine (the secondaries are tuned exactly the same way a non-CC q-jet secondaries are tuned).
Keep what you've got. Spend your money were it'll do some good.
Old Jul 5, 2003 | 11:02 AM
BillZ28's Avatar
Car: 84 Z28
That's what I put on mine. I don't miss that frickin Quadra-Jet one bit.
Old Jul 5, 2003 | 08:57 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Gas mileage is a factor, but I do need something good for those "special times"
Old Jul 15, 2003 | 06:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A Qjet will flow something like 780cfm IIRC. Its more than big enough for a tough street engine.
Old Jul 16, 2003 | 12:32 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
The CC carb on my L69 works great. Most "carb" problems are really weak ignition or fuel supply.
Old Jul 25, 2003 | 02:57 AM
Air_Adam's Avatar
I agree... thought my carb was running rich, so I changed the cap, rotor and wires, and the problem was 95% fixed (the other 5% was it running a little rich)
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
