Turbo Update
Old Jul 14, 2003 | 01:30 PM
Doward's Avatar
Turbo Update
A couple things... I'm in the midst of a sudden move,so the car's not getting the attention she deserves... pipes are done up to the Y/Flange for the turbo. I pulled the turbo apart, and cleaned it. Next i'm going to port it.
I have had a bit of a setback. Turns out not ALL 5.0L FORDS USED 19PPH INJECTORS!! ONLY the 5.0 HO did. So I've got a set of 15pph injectors, freshly cleaned, with nowhere to go. Check my ad in the classifieds -
https://www.thirdgen.org/classifieds...tgo?adid=25141
Paid $75 for the cleaning, got them for free, worth about $120, selling for $60.
I'm on the trail of a set of 22lbs/hr injectors tho, so all may not be lost!
Old Jul 14, 2003 | 05:46 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What color were them injectors? Also, what is the "part number" on the side.
I have a set of what I belive are ford 19pph injectors that I had installed in my dodge, not being used. If them 22lbs dont come thru, get with me. We might work something out
Old Jul 14, 2003 | 10:30 PM
Nixon1's Avatar
19 lb/hr injectors are color-coded orange.
If I had the money I'd have a set of 24 lb/hr's and a matching MAF and I'd send my 19's your way...but I'm broke.
Old Jul 15, 2003 | 10:32 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
i've got a set of what are supposed to be 19 pph out of a camaro. i don't know if they need cleaned or anything. there's 8 of them. they're just layin out in the shed right now.
Old Jul 16, 2003 | 03:14 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
so close but yet so far....keep it up you get there
Old Jul 16, 2003 | 03:20 PM
F585's Avatar
Shut up and go get my harness so I can prepare for my turbo
Old Jul 16, 2003 | 05:19 PM
Doward's Avatar
LOL, thanks for the support guys... I'm working on getting a set of 22lb'ers, and the current chip will do fine... it'll be slightly rich, which should be ok with it being turbo'd and all. BOV and everything else is in. The ONLY thing left to buy is the boost gauge. I'm working on it every single spare second I have, but with 2 jobs (work 4pm-6am then sleep) it's really hard. I'm getting there tho!
Old Jul 17, 2003 | 11:57 AM
IROC57TPI's Avatar
Hey keep us posted. And GET PICS!!! Oh, btw- I got some stock LT1 injectors. Not sure of the size...either 22 or 24lb. I'll take $75 for the set of 8. Do what u want with the extra 2
EDIT:
I don't have the time to go read the entire turbo post for specifics...please somebody give me a rundown of the electronics you're using. I'd like to replicate this setup in a Chevette or Vega. I think something that weighs less than 2900lbs. would fly with a turbo'd 60* V6
Old Jul 17, 2003 | 01:09 PM
Doward's Avatar
Why a Chevette or Vega? My V6 Camaro weighs 2950 with a half tank, and without my 200lbs of me in it....
Electronics?
Stock, with a recalibrated prom. That's it.
Old Jul 19, 2003 | 06:10 AM
Doward's Avatar
Sorry for the lack of updates... real quick, exhaust is welded, Y pipe/brackets go in Monday, and turbo is cleaned, primed, clocked, and set to go in... barbs set for the oil/water, and associated lines are ready. Air intake from filter to maf to turbo is done. Connection from turbo to intercooler is ready. Need to run from intercooler to TB still.... and the injector scene is still in progress....
Old Jul 19, 2003 | 08:23 AM
Dale's Avatar
Engine: 350 S-TPI
Well quit typing and get to work J/k, thanks for update. Hope the weekend is decent weather for you to work.
Old Jul 21, 2003 | 10:29 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
Doward, I got the turbo almost set up in Autocad so I can begin to work on the bracketry, however we'll need the car over here to fab the bracket to the car itself.
*just wanna do this one cuz AFM doesn't have it... *
Old Jul 22, 2003 | 02:22 PM
Doward's Avatar
rofl.. Y pipe is back... about to go see it, then guess what?
BACK TO WORK. 8am-11pm. Jeez.
ANYONE IN CENTRAL FLORIDA! BE AT THE OCALA THIRDGEN MEET SATURDAY!
We should have her running then!!!!
Lata...
Doward
Old Jul 22, 2003 | 03:39 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Lata...
Doward
running... with the turbo in it?
sweet. Take many many pics.
Old Jul 25, 2003 | 07:05 AM
Doward's Avatar
TODAY. My ***, I worked 5pm-8am, and I refuse to sleep. I will do everything I can to have that turbo up and running TODAY.
Old Jul 25, 2003 | 07:06 AM
Dale's Avatar
Engine: 350 S-TPI
As much as I want to here you saying it runs, you need to get some sleep brother. Don't want you making poor judgement and have alot of crap to fix later cause of it.
Old Jul 25, 2003 | 09:04 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Take this advice. ^^
I've been there, done that.
Old Jul 25, 2003 | 01:56 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I'm excited. Doward, are you gonna dyno it?
Old Jul 26, 2003 | 12:14 AM
vortex's Avatar
Engine: 5.0
Doward over at Vortex's place, working on the turbo -
Yes, it'll be dyno'd... hoping to get pics of it at the Ocala fl-thirdgen meet tonight...
no making fun of the body, tho! Remember... turbo, then bodywork
I can already see some clearancing that will be done in the production run. With the suspension under load, the passanger side pipe is like 1/2" off the ground. Didn't get as tight as I thought - the driver side is only 1.7" lower than normal!
With all the work on this in the last couple days... I can honestly say guys, if it weren't for the fact I'm only $200 into this, I would never recommend building a turbo system from scratch. For the $$ spent, I'd put it elsewhere.
A turbo kit I'd be all over... but custom doing your own is INCREDIBLY time consuming, difficult, and the cause of more than one grey hair!
Old Jul 26, 2003 | 12:46 AM
The_Raven's Avatar
Agreed, but when it's custom I think there is more pride in it, and no one else will have the same combination.
Old Jul 26, 2003 | 07:48 AM
Dale's Avatar
Engine: 350 S-TPI
hince my l32 swap, but then found 2 others that had done it. :crys:
Old Jul 26, 2003 | 08:46 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
So, is it done? Running? More power? Wanna see!!!!! at least need an update.
SSC
Old Jul 26, 2003 | 10:53 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Let's go Doward...can't keep us waiting on this forever
Old Jul 27, 2003 | 09:44 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Heck yeah! I wanna hear a turbo strapped to a thirdgen V6!!! Sound clips! Sound clips!!
Old Jul 27, 2003 | 10:17 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
wtf?!?!
i need pics... or something. I cant wait any longer!
Old Jul 27, 2003 | 02:07 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
lol you guys tell the man to get some sleep now your bugging him for pics...MAKE UP YOUR MINDS!!!!!!!!!!!!! :sillylol:
Old Jul 27, 2003 | 03:40 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Hmm We can only conclude from the lack of updates that Doward finished the turbo project.
On the initail test drive the turbo spun soo fast his speed increased to warp 9.9 and he was instantly transported back in time. At this moment he is changing the history of travel as we know it, by the time this thread is read history as we know will forever be altered and all 3rdgens will have 2.8 turbo engines. fNord will have never exisited and there will be no such thing as an import automobile. Life will be good.
Old Jul 27, 2003 | 03:42 PM
Engine: 305 carbed
Axle/Gears: unknown
LOL, that sounds about right
Old Jul 27, 2003 | 03:53 PM
fly89gta's Avatar
Car: 2018 Camaro SS
No more Star Trek episodes for you mister lol
Old Jul 27, 2003 | 07:11 PM
vortex's Avatar
Engine: 5.0
Hey all, it's Vortex.
We got the turbo mounted and everything ready.. we took the car to get the Y-pipe welded to the pipes and the flange, as well as get the downpipe made and welded on, Well, we dropped it off and they worked on it for an hour after they were closed when we were already late for the 3rd gen meet. Got it back and found out that they took off all our mandrel bends in replace of new *sigh* crimp bends. So, we went to the meet and it was cool, even for a Mustang guy.
Anyway, The turbo is mounted, and the piping is done.. now all we have to do is the oil and water lines. and bolt in the inducting tracking... I start work Monday so time is limited, but 98% chance we should have it done by wednesday so that we can get it to the track for some real results for you.
Oh, by the way, we just had to start it, and it does spin... and best of all move some air... thought i saw doward drop a tear at that..
Laaaaaaaaate
Old Jul 28, 2003 | 12:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Damn; I think I would've killed someone. Did they at least give the bends back? Those were the Hooker mandrel-bends, right? At $30/bend?? Damn.
Glad to hear it's working out well!!
Old Jul 28, 2003 | 04:26 PM
vortex's Avatar
Engine: 5.0
no, they didn't give them back.. they butchered them coming off. and yeah, $100 for the bends.. so needless to say not only did that set back as far as $$ goes, but time as well.. and doward get your *** over here, im not running this lines by myself.... well, yeah, i will, but that will just mean i get more track time than you.. and im even donating a present to the cause..
Old Jul 28, 2003 | 05:59 PM
Engine: 305 carbed
Axle/Gears: unknown
MAn that sux about the bends, Cant you charge them for doin that? did they have permission to do that? I would way pissed if they did something like that
Old Jul 28, 2003 | 07:56 PM
The_Raven's Avatar
What were the bends that were replaced in there for, the down pipe? Maybe they were just jealous. LOL
Old Jul 29, 2003 | 12:04 PM
vortex's Avatar
Engine: 5.0
no, they custom made the downpipe which we wanted from them regardless of the crimp bends... however, the mandrels came from the manifolds forward towards the radiator... nice smooth flowing pipes instead we now have restrictive "eh" pipes... but at least the turbo fits and bolts up...
Old Jul 29, 2003 | 12:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That'll be the last welding job that shop sees in a while, huh?
Old Jul 29, 2003 | 01:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yea but reguardless of the crimp bends your still ahead of the game as long as the turbo does its job.
Pushing the project along here.
Old Jul 29, 2003 | 02:46 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
DOWARD+VORTEX
EDIT: spelling error fixed from post below
Old Jul 29, 2003 | 03:34 PM
vortex's Avatar
Engine: 5.0
DOWARD+VORTX
Theres an E in the name, mate...
Old Jul 29, 2003 | 07:02 PM
Nixon1's Avatar
You know I only live by Melbourne..not terribly far from you guys...wish I had the free time to drive over there and see it for myself!
Old Jul 31, 2003 | 11:04 PM
vortex's Avatar
Engine: 5.0
Doward here again, over at Vortex's place
Turbo setup is DONE. Kinda... sorta...
Well, just have to seal one pipe - the oil feed line. Shouldn't be a problem, though. Injectors/chip/piping/etc are all done. IC is in. Everything's together - coolant lines, oil pan tapped/line set (Vortex's own handiwork there - thanks man!)
Unfortunately, I'm working 16 hour days over the next 3. Nice $$, but no time.
Look for pics, results, and all next week.
Old Aug 1, 2003 | 12:08 AM
The_Raven's Avatar
I'll be waiting (im)patiently.
Old Aug 1, 2003 | 08:26 PM
vortex's Avatar
Engine: 5.0
Well here are the pix as promised.. even one including my sexy hands...
complete assembly
intercooler with ducting
drivers side looking to pass.
Y-pipe
y-pipe (under)
top of turbo, custom wastegate adjuster
top of turbo & downpipe
b.o.v.
airfilter and ducting (drv. side)
T/b, b.o.v., etc.
Old Aug 1, 2003 | 08:36 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Congrats man!!!!! :rockon:
Old Aug 1, 2003 | 08:59 PM
The_Raven's Avatar
Interesting, intersting indeed.
One thing I will mention, is that elbow you have on the IC, use another clamp, or maybe a pair and put it/them on the area that actually bends, this will keep it from ballooning under boost, I know I am using the same type of tubing on my swap, until I get to higher boost levels and need the silicone bellows.
Looks like there is a little more room between the engine and the rad than in my Jimmy, I wish I had that amount of room, I would have mounted mine there as well.
Just wondering how ground clearance is, with the Y-pipe? Doesn't look like it hangs too low, but I'm not especially familar with how low the crossmember hangs on the F-body, I like how it runs though.
I can't tell from the pics, Where is your oil drain back, going to? It also looks like you mounted the turbo "upsidedown", if that's teh case, did you turn the bearing housing to compensate, or did you just turn the turbine housing over?
Keep it up, great to see DIY projects coming together.
Old Aug 1, 2003 | 09:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
looks good
And I thought I had a lot of pvc going on.
How are you planning on getting air flow to the intercooler? Remove one of the headlights & rig the other to be both high & low beam?
keep it up
Old Aug 1, 2003 | 09:59 PM
Have you taken it for a drive yet? How does it run?
Old Aug 1, 2003 | 10:31 PM
vortex's Avatar
Engine: 5.0
That shouldnt really be a problem as we're only shooting for 6 psi and between the wastegate and the B.O.V, it should maintain well.
perhaps.. but the fan on these sticks out like 6" at the top and like 2 or 3 at the bottom, so i found a way to pull the fan to where its parallel with the radiator.
The y-pipe goes vertical so no prob there.. the manifold pipes fit real nice and tight up against the underside so it works great.. sadly to say better than one of our mandrel bent sides..
The oil drain pack is a threaded barb for a hose that is drilled and tapped into the oil pan... its secure. The turbo is upside down as compared to a 1G DSM, but Doward clocked the compressor housing so youd have to ask him about the bearing... i believe he said thats what he did tho...
The intercooler sits where the vacum canister did, beneath that is a short pedistal that it sits on... we pulled that, and beneath that is a drop in tray kinda like a floor pan that is pinch welded in.. we just pop those welds and viola (vee-ola for tiger) you have ground.
Unfortunately no... we had one pesky setback with oil seepage.. the oil line going into the turbo leaks slightly due to a damaged ferral so we will change that, hook up our boost guage and dial it in for the big test... updates, time-slips, dyno pulls soon to follow...
Old Aug 1, 2003 | 10:38 PM
Doward's Avatar
AH... my own name again
Yes ladies and gents, it's set up. I know it's not too pretty, but this is a rough prototype - production will be stainless steel mandrel bends throughout (no pvc, sorry, lol!)
We've just got a couple oil problems to take care of, then she'll be taken to the track. Vortex's Mustang runs a 14.7 - I'll probably line up against him Monday or Tuesday, and see how close to a mid 14 we are.
Here's hoping!!!
Doward
Old Aug 1, 2003 | 11:00 PM
Engine: 346ci LS1
Transmission: MN6
Looks really good man!!! I look forward to hearing about your track times!! :hail:
