Back halfed part II [ Body & Paint]
Old Jul 20, 2003 | 07:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The class sequel to ya better fix it now before its to late.
<P>Stage 1 can be found here:
<BR><A HREF="https://www.thirdgen.org/techbb2/showthread.php?s=&threadid=189093" target="_blank">https://www.thirdgen.org/techbb2/sho...hreadid=189093</A>
<P>I spent the last two day working on the left rear.
<BR>I am lazy about getting pic but once I get going and am covered in
bondo dust, pics are not important.
<P>I am only doing the back half of the car for now.
<BR>Doors and fenders might just get replaced but like my floor and interior
project.
<BR>I am taking care of the not so easily replaced parts now and before
its to late..
<BR>I may even paint just the back half when I am done. It will at least
look halfway nice.
<P><IMG SRC="http://viragotech.com/rearleft.jpg" HEIGHT=500 WIDTH=1084>
<BR>&nbsp;I started on the left rear as i was the worst of it all. Had
to work in some metal and had some holes to fix/bondo.
<BR>Lots and lots of sanding between coats. almost 2 big tubes of spot
and glaze putty getting it baby butt smooth.
<BR>I still have some work to do by the door.
<BR>&nbsp;
<P><IMG SRC="http://viragotech.com/rearright.jpg" HEIGHT=498 WIDTH=779>
<BR>GOt real lucky on the right rear as it is all just surface rust.
<BR>I sanded and painted it with spray can stuff a few years back and it
is now flaking off.
<BR>I may find some small holes once I start blasting.
<BR>&nbsp;
<P><IMG SRC="http://viragotech.com/rlclose.jpg" HEIGHT=595 WIDTH=1535>
<P>I just can't stop playing. Looks likes the death ghost image of the
rust monster in my sanding.
<BR>&nbsp;
<P>Matt
Old Jul 21, 2003 | 08:38 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
looking good, Very smooth.
I just hope that you didnt put too much Bondo on there. If Bondo gets too thick, it will eventually just basically fall off in big chunks, which really sucks.
Old Jul 21, 2003 | 12:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I got a good example of that on the left door. Looks like someone [a woman] went through a drive through and rubbed the door on one of them yellow poles. You cant really see it but with the flaking bondo you can see the "waves" in the metal the pole did while rubbing. It look to have a whole small can of bondo on it.
Matt
Old Jul 22, 2003 | 08:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did you spray some kind of rust-killer on the rust? If you just sand it off, it'll come back... trust me... I did the same, just sanded it away, made it all shiny, and figured that I removed all the rust. A few years later ...
Old Jul 22, 2003 | 01:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Tom,
I have been sand blasting everything down to bare metal and beyond and used some CC prep and paint. I got one of the handy dandy spot blasters that hold a few cup of sand. Made sure and went around each spot and chased down any rust that had not come through the paint yet.
I really can't afford to blast the whole car but I would like to. Not sure how I will "sand" the rest of the car to rough it up. I hear beach sand is bad and good blasting sand is $30-40 for a 5 gallon bucket that does not last very long when your losing it everywhere.
Matt
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1nastygta
Aug 8, 2015 07:38 PM
