Dyno #'s with 383/AFR 190/LPE219/SR
Old Jul 27, 2003 | 03:28 PM
JohnnyIroc's Avatar
Car: 85 TA
Best pass of the day was 368.1 rwhp and 425.5 rwtq. Highest torque was on the first run at 431.8. The peak power was at about 4950 rpms, and peak torque around 4100 rpms. I know this motor should pull to atleast 5600 rpms but after 4900 the car was running way to lean and by 5800 rpms the air fuel was 13.5 to 1. If i knew how to post the the pic of the dyno sheet i would. Later
Old Jul 27, 2003 | 03:37 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
:rockon:
Gotta love this combo.
Old Jul 27, 2003 | 07:03 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Re: Dyno #'s with 383/AFR 190/LPE219/SR
I'm sure someone on here can help you with the posting of the dyno sheet......sure would like to see the curves.
and congrats on the numbers.
Old Jul 27, 2003 | 07:57 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
He's cooking with Betty Crooker!!!
Awesome combo, hope mine does something similar!!!
Old Jul 27, 2003 | 08:08 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Congrats dude. I'm hoping for very similar numbers after my cam swap and port work. The only differences between mine and yours will be unported heads for me, different ignition system, and I don't know what kind of compression you're running?
I'm also planning on having Ski burn my chip....from all I've read he's the man.
Let me know when you get some track numbers for that thing.
Old Jul 27, 2003 | 11:32 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Those are great #'s and are on par w/ others that have that combo whose cars run great.
I'd be happy w/ those #'s with my new cam. Everything else is pretty much the same as your setup except for the auto trans. My goal is going to be 475-500fwhp. I'll be happy either way as long as I'm running close to 12 flat like you and BuckeyeRoc.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
