TB flow bench data
Old Aug 6, 2003 | 10:57 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
TB flow bench data
This one gets rehashed over and over --- "How much air does a TBI flow?"
Here's one link, of many, on the CF (Crossfire) Vault that have measured data. You can search there for the others.
The key points you need to remember is that Crossfire engines (LU-5 305 on 82-83 Fcars; L-83 350 on 82 and 84 Vettes) have two separate near-identical single-bore throttle bodies. The injectors on these are the same type used on TBI Fcars (a CF Fcar is a TBI Fcar) but they usually have slightly mismatched pairs (64 and 66 lb/hr used on the Vettes for example) for reasons I won;t mention here.
The single bore on each TB is identical in inside-diameter (42.8 mm or 1 and 11/16 inches) to the ones used on the dual-bore TBI used on 305/350 on F and Bcars of later model years (1989+). So the flow data from the below link is applicable to the dual TB units used here. CF engines use two single-bore (or single-venturi) TBs, and the single TB used on 1989+ Fcars is a has dual-bores. Systemwise, the cross sectional (flow) area is the same for both.
http://www.crossfire.homeip.net:81/c...hrottle+Bodies
Other useful points -- Vette owners modify their TBs to larger bore diameters to get more airflow, and some of them are area-wise the same as the 454 TBI unit. The so-called ultimate TBI mods don't have to be performed to the same degree on CF TB units because the casting already has the right entry shape. Look at TBI pix of a CF TB, compare it to a 2v Fcar TB unit, and you'll see why.
Read and search for more info on the CF Vault if you want more. Don't ask me -- I'm just the messenger.
Old Aug 6, 2003 | 11:32 AM
kdrolt's Avatar
Engine: LO3, LO5
Addendum to this post, and summarized from looking over several posts at the CF Vault:
Stock single bore TB (42.8 mm or 1.68" inside diam bore)
one injector tower gasket @13.6"
285 CFM (each), 570 CFM together.
two injector tower gaskets @13.6"
286 CFM (each), 572 CFM together.
This one, 572 CFM together, is the closest to a stock Fcar 2bore TBI
Stock TB, injector tower REMOVED for study @13.6" - 288 CFM (each) total, 576 CFM together.
stock single bore TB bored to 2" inside diam
333 CFM (each), 666 CFM together.
stock single bore TB bored to 2.130" inside diam
379 CFM (each), 758 CFM together.
Holley dual bore 2" inside diam TB
670 cfm (their rating, unknown depression)
Notes
1. the extra injector tower gasket (stacking them vertically to raise the injectors) makes a slight difference on the 2" and 2.13 TBs, but makes almost no difference in airflow on the stock-size TB's. You'll have to find the orig posts on the CF Vault to see the before/after comparo of single v double gaskets.
2. Removing the injector tower means removing both the injectors and the injector mounting. There is almost no difference in airflow, so the injectors/tower really don't impede the airflow at all, contrary to what's often seen on TGO.
So the above measurements refute a mythical "improvements" made by TGO TBI owners: raising the injector to increase airflow past the injector.
To compare other depressions (aka the pressure differential across the TB when it was flowed):
new_flow = old_flow*sqrt(newdp/olddp)
where newdp and olddp are the new and old depressions (depression is the height of the column of water used in the test manometer). Depression is a form of a pressure measurement, rather than a vacuum measurement -- so take care not to mix units of pressure and vacuum.
Lastly, more depression means more pressure difference and hence greater flow. The above equation is an approximation along a flow streamline, so it's useful but it's not perfect. HTH.
EDIT: See also
TBI AirFlow - FULLSIZEforums - Chevy Truck
Last edited by kdrolt; Nov 3, 2006 at 07:29 AM. Reason: added Fullsize Chevy thread on TBI airflow
Old Aug 9, 2003 | 02:34 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
So, based on the above flow numbers, one could assume a dual bore TB with a 2.2 bore size would flow >800 cfm?
Old Aug 17, 2003 | 08:44 AM
Lionsden's Avatar
They might look something like this.
Old Aug 17, 2003 | 03:45 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
are those flow numbers at 3"HG or 1.5" HG?
Old Aug 18, 2003 | 06:15 AM
kdrolt's Avatar
Engine: LO3, LO5
Neither.
Each data point in the 2nd post above says "... at 13.6", which means measured steady-state at pressure difference equal to 13.6 inches vertical column height of water.
If I did the math right, 13.6" water equates to 0.99 inches of mercury (Hg), which is slightly less pressure testing differential than when testing at 1.5" Hg, so I would expect the airflow values to all be slightly higher if they were corrected for flow at 1.5" Hg. Use the equation listed in the earlier post to find the correction.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
