Power supply questions.
Old Aug 12, 2003 | 08:11 PM
Rage13's Avatar
Car: 89 Firebird
I'm wiring up my TQ lock up to work off a manual switch, only thing holding me back right now is where to pull the power from.. I have it all wired to hold upto 10 amps, also have a fuse as the first thing inline, so no worries there. Only thing I don't really want to do is put another wire on the battery, so where can I pull it from?
Old Aug 13, 2003 | 08:36 PM
Rage13's Avatar
Car: 89 Firebird
come on guys.. i really need some help here.. i'm going up to tampa this weekend and need the TQ lock up working..
Old Aug 13, 2003 | 10:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Normally it's power is pulled from the 'gages' fuse (ignition switched source).
Old Aug 14, 2003 | 09:30 PM
Rage13's Avatar
Car: 89 Firebird
crap, blew the 10 amp fuse i put in... how much power can that lock up valve use? i ran 14 gage wire for the whole system, the switches i used can hold up to way more then any car would ever see.. only thing i'm woundering now is, is that lock up valve made to take 12v power thu it? and how meany amps would it draw?
Old Aug 14, 2003 | 09:53 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
I don't know if this will help out any, but hopefully it will. When I ran a hot wire to my fan, I just pushed the connector into the slot in the fuse box labeled Battery. It's worked for about 2 weeks without a problem. Hopefully this will help.
Old Aug 14, 2003 | 11:34 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
there should be spare slots on your fuse panel that can power the line. look for an empty slot that says "IGN" or "ACC" and plug your line in to that, you shouldn't have a problem.
Old Aug 15, 2003 | 07:40 AM
Vader's Avatar
To answer your other question, about 350-500mA. If it blows a 10A fuse, you have a wiring or device problem.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
mike_c
Aug 27, 2015 04:32 PM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
