Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Can't post on the Classifieds or add your ride to the Rides??
Old Aug 28, 2003 | 01:40 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Delete your cookies and/or turn off your personal firewall while posting to those sections. Make sure that Remember Username and Password is set to Yes in your User Cp.
If you're having problems with getting logged out of the board and are forced to log in all the time, or if you can't post a Classified Ad or post a Readers Ride, do this:
Log in to the board.
Click on the USER CP link.
Click on EDIT PROFILE.
Make sure "Automatically login when you return to the site? (uses cookies)" is set to YES.
Make sure "Browse board with cookies?" is set to YES.
Then click on SUBMIT MODIFICATIONS.
Now would be a good time to DELETE YOUR COOKIES. After you log on again, everything should run properly for you.
If you still can't post a Classified Ad, then keep reading:
You are probably running a software firewall on your computer and you have "Browser Privacy" enabled (or something to that effect that hides your browser info and referrer info). Disable it. Go to the webpage that your software company maintains if you need help figuring it out. You can re-enable it after you're done posting your ad, but you'll need to disable it if you want to post again.
customblackbird
Aug 15, 2021 10:16 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Linson
Aug 21, 2015 02:12 PM
sreZ28
Aug 14, 2015 07:48 PM
