Cheap New Mods...New Times
Old Sep 13, 2003 | 09:26 AM
smithtc's Avatar
1/8th mile track
Previous best was 8.76 at 80.93 mph
New mods are 1" siamesing of the LTR Accel runners at the top where it meets the plenum, and a 160 degree thermostat.
I did not siamese the plenum...just the runners about 1" square.
Here are the runs: Letting the transmission shift on its on. Somewhere around 5000rpm...footbraked to about 1000-1100rpm each time. Goodyear GT+4 tires. Stock onverter
1st was a 10.67 @ 62 mph w/ a 2.45 60'.
I basically just tried a clean off of the tires. Pulled out of the run when shifting into 2nd with tires spinning and going sideways towards the center. Got back into it a little, but had detonation so pulled up again and coasted. Still beat some import next to me...funny.
Run 2: Better burnout temp @ 160-180 (?) ...Had the "rattling" noise all the way down the track. Some spin on take off.
60'.....2.030
330'...5.811
594'...8.409
1/8.....8.993 @ 77.05mph
Run 3: 1.5 gallons of 110 octane added. Car real cool... Just to the right of the 100 degree mark. Cutout opened up. Not much spin this time. Problem, though. I do my burnouts with gear in 2nd. Forgot to put it back to "D"...so I went through the traps in 2nd. Seemed to pull up to about 5400 rpm ok...but went through at about 5600rpm. If the tach is correct. Don't think it will pull anymore past that 5600 rpm mark.
60'.....1.987
330'...5.642
594'...8.153
1/8.....8.722@78.96mph
Run 4: Car a little warmer...maybe 150-160. Trans in "D" this time. Some spin at start
60'.....2.031
330'...5.698
594'...8.217
1/8.....8.785@ 79.2 mph
Car didn't feel stronger. But I got better times. Maybe midrange is a bit better.
Anyway, next mod will be some stock ported heads w/ 1.6 roller rockers.
italiano67
Dec 11, 2016 09:21 AM
dutch930
Sep 11, 2015 06:58 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
