Twin supercharged TPI inside
Old Sep 26, 2003 | 07:26 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
A friend has a nice "project".......
Twin supercharger, to have more boost at lower rpm's.....
Old Sep 26, 2003 | 07:27 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
one more.....
Old Sep 26, 2003 | 11:47 AM
MdFormula350's Avatar
:rockon:
Old Sep 26, 2003 | 02:27 PM
CamaroFreak406's Avatar
Car: 1991 Formula
Engine: 350 firebreathing inches of Small Block Chevrolet
Transmission: A 700R4 that has trouble handling the formentioned 350.
What does that guy do for a living? He would make a great plumber. Looks like a boost maze in there.
Later, Garrett
Old Sep 26, 2003 | 02:57 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
sweet
Old Sep 27, 2003 | 01:24 PM
Zac's92's Avatar
those look like turbos that he built a pulley on the turbine end of the shaft.
Does the drivers side compressor feed the passengers side one? thats what it looks like
that is kick ***
Old Sep 27, 2003 | 01:51 PM
D M N's Avatar
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Originally posted by Zac's92
those look like turbos that he built a pulley on the turbine end of the shaft...............
Is that possible??
Does superchargers are called centrifical superchargers they work like turbos except they use belts instead of exhaust to power the compresser
Old Oct 3, 2003 | 06:55 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Originally posted by D M N
Is that possible??
you probably could, but the compressor wouldn't spin fast enough with out a gear box multiplying the RPM. But to answer your second question, yes, instead of exhaust they use a belt off your crank to spool up.
Old Oct 6, 2003 | 01:23 AM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Mother of all that is some serious plumbing!!! I thought my compartment was *tight*. Anyway whats the deal with the belt that drives it? It looks like its about a 1/2 an inch long?
Old Oct 6, 2003 | 03:08 AM
Zac's92's Avatar
If you look closely at the pictures there is some kind of step up ratio to get the impeller to spin faster. The shaft with the pulley on it is not inline with the center of the compressor housing. there has to be a gear multiplication in there.
Old Oct 6, 2003 | 12:57 PM
dans82bird's Avatar
Engine: 302
exactly; and it spins that compressor up at around 60,000 + rpm
Old Oct 6, 2003 | 12:58 PM
dans82bird's Avatar
Engine: 302
One question though, why is your buddy using TPI?
Old Oct 8, 2003 | 05:45 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
gta324, We must have a common friend =)
Yes, those are two superchargers that he built using the compressor half of two huge turbos and the gearboxes from a electrical wheelchair. The grearbox is a step down from the electrical motor to the wheel axle, but he is running it backwards as a step up gerbox instead. The belt pulley is on the wheel axle.
If you look you will also see that he made the dump valve and fuel pressure regulator from billet aluminum. The box behind the right headlight is an air-water chargecooler that he also built.
This a few pictures I took.
(Click to enlarge)
Old Oct 8, 2003 | 05:53 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Yes...
We use to update each other about our projects......
Hows it running?
/N.
Old Oct 8, 2003 | 05:58 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
He is having some problems ... He is blowing the pipes apart and the chargecooler exploded in half ... but that has been repaird and should be much stronger now.
Old Oct 8, 2003 | 01:10 PM
Bobalos's Avatar
that has Dick Datsun, all over it. http://www.gatorsuperchargers.com
riddle of the day:
What do you call a turbo, that is belt driven that has a step'd up drive ratio?
how about a centrifugal blower?
BW
Old Oct 8, 2003 | 01:21 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
OMG I didnt see that before! He has the staged! one into the other!
Old Oct 8, 2003 | 04:14 PM
schwitzer's Avatar
I can imagine that some of you wonder why anyone spend time to install a 2 stage compressor under the hood.
I have since the last 4 years a homebuild single centrifugal compressor installed (se pictures above), based on a Schwitzer truck supercharger with very good result. Maximum boost with this setup is 7,5 psi at 75 000 rpm. My goal is from the beginning to see how strong an almost standard 350 TPI can be, because of the TPI intake is this engine not a high hp setup but very strong at low rpm.
355 TPI
8,5:1 CR KB pistons
Compcams camshaft (for supercharged engines)
1 5/8" headers
Saab Aero injectors and boostpump
Computer is a standard xxx165 ECM MAF rebuild to a Holden xxx808 MAP (2 bar Buick)
Techedge Wide band lambda + EGT
With the new compressor based on a KKK supercharger in serial with the Schwitzer compressor I expect to see 20 psi boost at 5500 rpm and no belt slip.
I have run this 2 stage setup for a couple of weeks and it seems to work, high average hp that suits my 2.73 rearend (except a few bugs like a exploded aftercooler). Two hours ago my th700 went to heaven, maybe time for a 4l80e.
Old Oct 8, 2003 | 06:12 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I wasnt knocking it as a matter of fact I would like to know what kind of pressures are seen between them
Old Oct 8, 2003 | 11:39 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Welcome Kristian...
/Niklas
Old Oct 9, 2003 | 01:39 AM
schwitzer's Avatar
I must correct my last reply, 20 psi of boost is what the compressors are capable to generate for the required cfm. The higher boost the better,then I can get high boost at low rpm and at 5500 rpm(engine) bleed out air to the atmosphere thru an adjustable regulator (big pressureregulator controlled by a electric solenoid) to avoid too high pressure. Maybe a turbo supercharger have been better to achieve this, but this is a more unusual solution.
Pressure between the compressors are theoretically 7,5 psi at 5500 rpm (have not been able to measure that yet) then the 2nd compressor will se higher airdensity and boost the pressure up to 18-19 psi. // Schwitzer
Old Oct 9, 2003 | 04:08 AM
83 Crossfire TA's Avatar
Makes sense to me… it’s a cool bit of “doing it your own way” mixed in with “can you make it work…”
355 TPI
8,5:1 CR KB pistons
1 5/8" headers
Hum… can you elaborate on this? Are you saying that you’re running your standard 165 with a 2 bar map in the place of the maf? If so I’d love to hear details since I don’t think I’ve heard of anyone doing something like that (closest is probably converting the GN maf setup to map) and I have a car with a 165 in it that will eventually see some boost.
I’m betting (correct me if I’m wrong Schwitzer) that part of the deal is that you can’t really spin up the compressors to where they typically would spin up to driven by a turbine so the staged setup is to accommodate for the bigger compressors spinning slower. Centrifugal superchargers use the same basic layout of a turbocharger, but use compressor wheels designed especially for the lower rpm’s that they typically see.
Huh, that raises an interesting question… what did you do for the gear box output shaft bearings, anything special? Not many bearings are rated for 75,000rpm and the setup used in turbos will not play nice with the side loads that you’d get from a gear box.
Old Oct 9, 2003 | 05:05 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Crossfire: Go to DIY PROM board and do a search for 808 code and you will find all the info you'll need.
(MAF to MAP posts)
You could also run a 2-bar MAP with the 730ECM the same princip. But with the 808 code you can use your old 165 ECM and dont have to repin and so on.....
Old Oct 9, 2003 | 06:41 AM
schwitzer's Avatar
Yes, my relative small compressorwheels have that disadvantage. I´m running them at the lower end of the compressormap (effic.), they should run at 110 000 rpm for best result. That´s the reason for my 2 stage coupled superchargers.
The biggest problem from beginning is bearings and output shaft, outputshaft must be as short as possible and the bearings must have large clearence (gap between moving parts).
Today I use 6202 ZTBH C3 bearings rated only 40 000 rpm, they can stand one season and are cheap (20$ each).
Yes I use my old 165 MAF with 2 bar MAP, it works fine. Some cables must be relocated and some tables must be rescaled but this is simple. You will also lose your knockretard, in my opinion they have too many false signals especially when using a colder thermostat (more noise from engine). Instead I uses a medical stetoscope bolted beside knocksensor, then I can hear pinging with my ears. Have also connect ESC module to a LED for visual control.
// Kristian
sorry for my school english
Old Oct 15, 2003 | 01:24 AM
AlabamaThunder's Avatar
Car: 1986 IROC-Z, 1990 RS
Engine: 383 Stroker TPI, 350 About To Go In
Transmission: 700R4 W/ Shift Kit And Stall, 700R4 W/ Shift Kit
Okay, Obviously a plumer can't polish....
All that wonderful motor and that TPI ain't shiney?
WTF is up with that?
To the owner nice...very nice....but polish the plenum and runners please.
:hail:*DROOL*:hail:
Sorry I'm a nit picker
Old Oct 15, 2003 | 06:34 AM
schwitzer's Avatar
:hail:*DROOL*:hail:
The only excuse I have for the dirty TPI is that a polished surface is not optimal for cooling and dirt can´t affect the tourqe curve.
// Kristian
Old Oct 15, 2003 | 10:42 AM
Guido's Avatar
Car: 2000 Trans Am
kristian, if I were a betting man, Id bet that polishing wouldnt hurt the cooling much in this case. LOL
either way, looks damn nice to me!!
Old Mar 30, 2009 | 07:34 PM
Cr4zYH3aD's Avatar
Re: Twin supercharged TPI inside
any news about that ? or the owner ?
Old Mar 30, 2009 | 11:55 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
He has now a single turbo setup.
/N.
toronto formula
Nov 10, 2015 06:17 AM
PestilenceIV
Aug 20, 2015 03:32 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
Sanjay
Aug 12, 2015 03:41 PM
