turbo or TT possible with stock ecm????
Old Mar 30, 2009 | 07:02 AM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
is it possible to run a turbo setup with 1989 chipped pcm and stock maf?
expect to run 4 to 6 psi on a 1996 lt-1 engine with distributor in the rear and trans am 89 pcm obd1- retro fit
i know im gonna need big injectors, big fuel pump, fuel pressure regulator, etc.
and my chip guy alvin at pcmforless.com told me that i will max the maf.
and will not burn me a chip for that setup at distance.
any issues?
in just looking around if the project could be possible before i waste money.
Old Mar 31, 2009 | 12:02 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: turbo or TT possible with stock ecm????
Possible yes, together with a MSD BTM and a FMU you could probably get some good results with alot of tuning....
But you should consider swapping to a SD system, 730ECM and $59code or a DFI unit...........that would be better.......
my opinion.......
/N.
Old Mar 31, 2009 | 07:00 AM
FOX-GTA_89's Avatar
thanks I already know about MSD btm but never heard about FMU, sd system, 730 ecm is the 1992 stock ecm?, DFI unit, 59$code (piggy back)???
sorry im not good at electrical and programming.
Old Mar 31, 2009 | 08:13 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
FMU = fuel manage unit, raises the Fuel pressure depending on boost, higher boost -> higher Fuel pressure -> more fuel
730ecm is a ECM unit from ex TPI 90-92 but is used in many others....
$59code is a "chip" code developed from $58code from a GMC Syclone, it can be used in a 730ECM and allows fuel and spark tuning up to 30psi of boost ans closed loop with WBO2......
DFI= stand alone ECM, Accel, FAST, Holley, Megasquirt, electromotive, Bigstuff3, NIRA and many others..........
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
camaro71633
Sep 1, 2015 10:24 AM
marcusaw
Aug 10, 2015 08:13 AM
