9.46 at 141 with a *stock ecm*
Old Sep 26, 2003 | 10:05 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Mark Jackson just went a 9.41 at 141 with his GN.
Using a MaxEffort MAFless Chip.
Oh, on the default settings.......
Oh, and there was a fair amount of time refining things on an ecm bench to get the tweaks right in the modified code.
As far as the engine management changes needed, it was converted to MAP, and swaped out the injector drivers.
83 PPH injectors in this lil v6.
I'd tell you more, but I'd have to shoot you afterwards.
LOL,
9.4s,
WOW,
Kinda cool being associated with a project that goes that fast.
Like I've been saying, source code, ecm benchs, and testing all pays off.
And there is no fudging of IC numbers, guessing of AFR, etc..
Steve (Mr Maxeffort), and Mark have done their homework.
Old Sep 27, 2003 | 12:05 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Ahhh, the wonders of a power adder!
Old Sep 27, 2003 | 12:21 AM
funstick's Avatar
good work. now get it into the 8's with the same ecmn and still be able to street drive it. ill really be blown away then. and looking at the injector size id think 8's were just some boost away.
Old Sep 27, 2003 | 09:14 AM
Vader's Avatar
...or some cubes.
Those numbers are really starting to make that twin T76/406 look pretty inviting. Now to only find a frame that will take it all...
Old Sep 27, 2003 | 11:51 AM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
Last year at Etown in the time trials I had a Turbo/Nitrous fed GN blow past me right at the traps at 150+ MPH.
You might ask, at the traps? Yeah right. Well he only turned a 12.7 sec 1/4 mile time! On regular street tires. His 60' time was 2.5 sec, lol.
The car looked pretty hairy, so when I almost got to the traps and was ahead in my beat 350 equiped motor running high 12s I was impressed, that was until he went past me like I was standing still. Scared the hell out of me.
Talk to the guy in the pits and he said he wasn't taking it back down till he got some tires under it. I agreed that would be a good idea, before he killed someone.
But as the fella above said, its amazing what power adders can do. 4 cylinders running 8s 1/4s.
Sorta like two groups of people climbing Mt Everest. One gets there by hiking and another gets there by way of helicopter. Both can say they reached the top I suppose. At the end of the day, it only matters however to the personal goals of each group.
Old Sep 28, 2003 | 10:46 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
A better analogy would be,
one group practising, and doing their homework, and then just going out and doing it, vs grabbing a back pack and getting halfway and wondering why they're having problems.
That was a 9.4 with the default settings. Default meaning conservative, ie just to establish a baseline.
He knows where he is tune wise, and doesn't have to guess, or wonder what's going on.
Now if he wants, he can look at his EGTs, WB, Plugs, and decide if he wants to crank it up. Or if he goes to another track or the weather is different he can adjust for that.
Bottom line is that he still did what he did with a stock ecm. He did his homework, and was rewarded with great results.
Old Sep 29, 2003 | 11:37 PM
87_TA's Avatar
Not To get off subject, But there is a new record on DOT tires that was set by a Grand National - The time was 7.98 @ 168 he expects to hit a 7.7 this year @ 180, That pass an intercooler clamp broke dropping boost to 25 lbs hence low trap speed.
Now are you ready for this? It was with a destroked 231,Destroked to 207 Ci - That gives me wood!
Old Sep 30, 2003 | 11:31 AM
leirch's Avatar
Bruce,
This is Brendan. I've stopped down by your house a few times with my dad and the 87 camaro. My uncle is Mark Jackson, the one I was talking to you about a year ago. I was at Norwalk last Friday when he ran the new setup.
I helped him burn the new max effort imagine, the revised one that Steve sent him
He thumbed down from A to 7 so he did adjust. The first pass was at 10.17 with teh defaults. He kept lowering the fuel each pass. His last and best pass was at 9.46 at 141.6. He was at 36lbs of boost down to setting 7 on the fuel.
And yes, that car is bruttal and VERY quiet. I've helped work on it first hand. Constant and very consistant 1.3 60's all day long.
Old Sep 30, 2003 | 02:40 PM
leirch's Avatar
Here are a couple pictures of the "stock ecm'd" car
Attached Thumbnails 9.46 at 141  with a *stock ecm*-jackson-launch-wheels-up.jpg
Old Sep 30, 2003 | 02:46 PM
leirch's Avatar
Old Sep 30, 2003 | 03:42 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
OK, he made changes.
A->7, that would be poistions 7-8-9-A, so he made 4 changes to go from a 10.17, to a 9.4?, that's still incredible in my mind.
Does MJ live up by you?.
Old Sep 30, 2003 | 05:59 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Verry nice.
Hey Brendan I'll ask also does he live near you? Next time I swing over id like to chekc out that GN.
I may swing over once you get the motor in the iroc if you dont mind. I deff want to see it in person befor snow fall.
Old Oct 1, 2003 | 12:33 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Holy sweet jesus
Nice car
Ughhh I need my motor back in...
Old Oct 1, 2003 | 01:10 PM
leirch's Avatar
Yes MJ lives a couple streets away from me. Chris, you let the secret slip
Anyways, i'm in the process of converting my 87IROC over to a GN setup. I have the wiring done and Janis transmission is going through the tranny right now. Waiting on motor mounts and such now.
Grumpy, drop me an email at leirch@hotmail.com , we can arrange a time to go over and see his car, you can talk to him and check it out first hand. Its approximatly 60miles or so from your door step
Brendan
Old Oct 1, 2003 | 02:47 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
all i have to say is wow.....:hail: :hail:
Old Oct 2, 2003 | 11:25 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Yes MJ lives a couple streets away from me. Chris, you let the secret slip Brendan
You never said anything about it being a secret.
Wiggles
Apr 12, 2011 03:47 PM
Captain C
DIY PROM
Jul 9, 2007 11:14 PM
smokefan
DIY PROM
Jul 4, 2005 12:33 AM
a73camaro
Jul 31, 2003 05:07 PM
91L98Z28
DIY PROM
Mar 9, 2002 01:03 AM
