Your not going to believe this!!!!
Old Oct 7, 2003 | 05:57 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
Im getting a 400ci BB, Turbo 400 Trans, and some speed Torque converter for get this ... $150! My boys friend ripped it out of his older (2nd gen) T/A. He said the block just needs to be honed(sp?) Ima build it up with some AFR heads, 230-240dr cam and prob a carb. I want more hands on with engines so ima just build it in my spare time. Im also looking at a 427-454 rotating assembly by feb too. peace
SSBO
Old Oct 7, 2003 | 06:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Uh, BB Chevy, or Pontiac?
Big difference.
(Oh, a 427 rotating assembly won't do you any good in a 400 BBC. The cranks are the same, and the pistons won't work - you can't bore it to 4.250". And, a 454 crank would give you a wierd, custom-pistons-required combo.)
Old Oct 7, 2003 | 07:05 PM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Big difference.
O really hmm well its a BB pontiac but it will do just fine with the turbo400. Well cant I get a 455 crank then? And where can i find them. Thanx
SSBO
Old Oct 7, 2003 | 07:44 PM
five7kid's Avatar
Installing a BBC is not easy. But, it's a lot easier than installing a Pontiac engine. There are numerous threads about that over on the Motor Swap forum. Try a search over there, see what you find.
Beyond that, you've about exhausted my knowledge on Pontiac engines. (Want to talk more about BBC's, I've got a little more left there. )
Old Oct 7, 2003 | 07:54 PM
ede's Avatar
ede
there are no big block pontiacs
Old Oct 7, 2003 | 08:01 PM
five7kid's Avatar
Well, it might be more accurate to say there are no small block Pontiacs...
Old Oct 9, 2003 | 11:19 AM
SSBlueOx's Avatar
Car: Camaro RS
Engine: 305ci TBI
Thanx alot man, yeah ima have to get new engine mounts and such but my friends are helping me too. Thanx again ima go check out that swap forum.
SSBO
