What part is this?
Old Oct 12, 2003 | 08:13 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
What part is this?
I was under the car the other day installing spon lca's, and adj panhard, eibach springs and kyb shocks. When I removed the panhard I found a part above it I didn't recognize. The picture is below. What is it? What is its function? Why would the bolts on it have been loose? Thanks- Efrain
Old Oct 12, 2003 | 10:22 PM
z28cdoyle's Avatar
Car: 85 IROC
Transmission: Tremec 5 speed
It is called the track bar brace or panhard rod brace.
The panhard bar attaches the rear axle to the car to control lateral movement of the rear axle. The brace strengthens the mounting bracket for the panhard bar.
There is no good reason for the bolts to be loose. It is not a go fast setup or anything like that. My guess is that they just came loose or perhaps some did not tighten them sufficiently when they were installed.
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
