Springs - tech data
Old Oct 23, 2003 | 05:35 PM
irocfan's Avatar
Springs - tech data
I need to know the following pieces of info... if anyone can help me I'd be very grateful!
What is the free length of a standard IROC spring?
What is the rate (lbs/inch)
What is the Diameter of the spring?
What are the end forms?
leading on from there for those of you with eibach etc aftermarket springs up to about 1" lower what are the specs of those?
Why am I asking these dumb questions? Basically I'm too tight spend about $550 (UK prices) on a set of springs when I can have them made to my spec for half that amount....
Old Oct 23, 2003 | 09:40 PM
laiky's Avatar
virtually every IROC camaro, according to my moog catalog used the pn 5662 spring in the front. the specs are as follows, they usually sell for about 50 bucks in the US.
specs:
inside dia. 4.085 inches
dar dia. .750 inches
install height 10.75 inches
load 1690 lbs
spring rate 707 lbs
free height 13.01 inches
Old Oct 25, 2003 | 03:22 AM
irocfan's Avatar
thanks Laiky... guess I should have said the $550 price would be for an Eibach set and not standard IROC ooops
have to admit I'm not sure that trying to get new IROC springs across here would be that much cheaper than a custom made set (shipping costs and then tax tax tax!!) or UK specialists charging whatever plus their 'cut' but I'll have to do the sums
Old Oct 25, 2003 | 07:39 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
I am actually putting in my eibach springs today and i noticed that the say made in germany right on the spring, perhaps you can get them directly shipped? I'm not sure at all if that is possible.
Old Oct 25, 2003 | 12:32 PM
irocfan's Avatar
I will admit that the thought had crossed my mind... and may still be an option for me to take I suppose that one of the advantages of going custom is that you can actually specify what you want (using the standard IROC springs as a starting point).. softer.. harder.. lower the choice is entirely yours :lala: rather than what a company decides is best....
Old Oct 25, 2003 | 05:53 PM
laiky's Avatar
actually hee's right eibach is made in germany, they are huge with imports and european cars. They must me available locally for you.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
L98GTA87
Oct 19, 2015 10:43 PM
Nervous2
Oct 8, 2015 10:53 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Amillionoh7
Sep 5, 2015 11:44 PM
