Tired of one wheel peal
Old Nov 11, 2003 | 10:41 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
ariigh well im looking for a good posi unit and some 3.73 gears to put in my 92 camaro with 28 spline axels....can someone point me in the right direction. its going into a 3.1 V6
Old Nov 11, 2003 | 11:58 PM
onebinky's Avatar
Powertrax makes a unit that works with the 28 spline axles. It is a gear-type rear though, not a clutch type so be prepared for some noise when you're turning. The one I had in my 92 RS was perfect until we started dumping on the power
Old Nov 12, 2003 | 11:59 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Did you break the Powertrax unit?
Old Nov 13, 2003 | 01:39 AM
onebinky's Avatar
Yeah, but technically it wasn't me
It happened after I sold it to my brother. I think he said that one of the springs snapped, but I could be mistaken. It was covered under warranty, but I think they are still dealing with the claim. For now, the stock unit is back in so he can drive it.
Old Nov 13, 2003 | 02:02 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Since it's a V6 the 28 spline axles in the rear should hold up fine (unless you get a V8, then I reccomend Moser axles) so you just need a posi unit and gears. There are a few different types out there. If you're looking for cheap, SLP has the Torsen take-out posi unit for ~$100, but it isn't the strongest be far. PowerTrax makes a nice locker (The No-Slip I think). Auburn also has lockers and regular posi units. Some people say they're not very good, but I can't say since I haven't used them. Eaton makes an excellent posi unit, but it is a little pricey, on the other hand it's completely rebuildable. As for gears, any big name gear manufactuer will be fine. Richmonds are known to whine, but they're stronger and better for drag racing apps. They're not a loud whine, but some people are annoyed by it, apparently their exhaust isn't loud enough to cover it up . GM makes gear sets that are good quality and don't whine, Motive and US Gear also make good gears. Hopefully that gives you a start, I know I didn't list all your options so let us know what direction you're thinking and we can give you an idea.
Old Nov 13, 2003 | 04:33 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Is this the $100 posi unit you speak of??? They are not very clear on the site. Only one even close to $100, why i ask.
http://www.slponline.com/view_produc...TNUMBER=64501T
Matt
Old Nov 13, 2003 | 02:18 PM
kfoley's Avatar
Car: '85 Z28
Yes, that's the one I was talking about. It's a good posi, but if you're running some decent numbers it might not last long. Of course whether you're getting traction or not plays a big part in how long it lasts...
Old Nov 13, 2003 | 02:28 PM
Pillsbry10's Avatar
well ive only got a v6 that runs pretty quick but nothing serious yet....would the slp work for awhile with my setup. right now i have a chip, pulleys, exhauste and pf&e headers and im gonna have shortly 3.73 gears aluminum driveshaft and 5speed swap...it would be nice to have 2 wheels spinning when im stuck in the snow this winter lol
Old Nov 13, 2003 | 03:10 PM
Pillsbry10's Avatar
what about a used Eaton unit....going pretty cheap on ebay right now, would this one work?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442157092
Old Nov 13, 2003 | 03:26 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
going cheap??? check back on it in 4 days, 23 hours and 58 mins.
I dought it will go cheap.
Id say that $100 unit is nice for a V6 28 spline posi. Once you went above and beyond what the V6 can do, you would want to switch axels anyways and would need a new posi unit.
Just a tip for ya [One thing with a posi is never run your cheap-o spare tire. To many of them have gone early from a flat tire and a trip with odd size wheel on.]
Really glad you started this thread though.
Matt
Old Nov 13, 2003 | 10:37 PM
kfoley's Avatar
Car: '85 Z28
The Zexel-Torsen will be fine behind a V6. That Eaton one will end up going for more than you want to spend since it's rebuildable. I'm guessing you've got a good shop lined up to do the gear install right?
Old Nov 14, 2003 | 12:04 AM
Pillsbry10's Avatar
i may just have to get the SLP, seeing as its pretty cheap and everyone seems to think it will be fine in my ride. actually im gonna do the install at my school, we already tore my rear end apart once to see what all was in it(and for the experince) so ill just take it there and do it, free labor =) ok so we have a pretty good idea for a posi, now what about some gears....i dont know much about them or what(if anythign) i would have to also install with them...im thinking just a little upgrade, say 3.73s instead of my 3.42s..any help would be apprecieated
Old Nov 14, 2003 | 01:28 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hey man, why I said thanks for the post. I had no idea I could get a posi so cheap. Next spare $100 and I'm gonna get one for my 6.
Myself Id like to go 4.10 as with my T5 I can deal with the RPM's and drive mostly around town. The highways are storage for orange barrels.
But I do not have access to all the tools and help so I will most liley just stick with my stock stuff. Unless the pinion must come out to put it in. Was hoping it would just be an "easy" swap. The ring gear bolts solid, its the pinion that you gotta adjust with crush washers or something???
Matt
Old Nov 14, 2003 | 02:14 AM
kfoley's Avatar
Car: '85 Z28
For the gear ratio, it depends on what your powerband is and how high you like to spin your motor. Final overdrive ratio is also important, if it's low you can have high gears and still get acceptable mileage and keep the rpms low on the highway. I have a little spreadsheet I made up to figure the different rpms/speed depending on the rear gears. It's on my webspace:
http://mypage.iu.edu/~kyafoley/speed...-speedcalc.xls
If you have any ?'s about it let me know.
Old Nov 14, 2003 | 11:07 AM
Pillsbry10's Avatar
hey no problem, im glad i found one pretty cheap as well....and since we have v6s we can go cheap and still get the perfomance we want =) and they say v6s arent good haha. i have access to some 4.10s at my school but i do a lot of driving around and that would rev my engine up way to much, like tonight im going to cincinatti and i live in evansville...basically im gonna be driving 1000 miles this weekend. so a minor gear change is all i want to do...ill have to check out that spreadsheet and see if it makes any sense to me if not ill get back to ya, time to go order that posi, its pay day
Old Nov 14, 2003 | 12:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ok.. heres a question...
whats the internal gear ratios of a 91 700R4.... the one behind my L03 if it makes a diff...
im about to do a search, but if someone just knows, it would not only help me to post them here, but anyone else that has a auto and loads that spreadsheet
Old Nov 14, 2003 | 03:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Im not sure if the RPM's would matter much. These well my little 2.8 loves them RPM's it revs so fast.
I conside our/my 2.8 very much like a bike. Its kind of like riding a 600. Its as slow as you wanna be but if you rev them gears out, it can get up and go.
Now gas mileage might varry but I wouldnt be afraid to crus at 3500-4000 all day.
Matt
Old Nov 14, 2003 | 10:19 PM
kfoley's Avatar
Car: '85 Z28
700r4 Gear Ratios
1st - 3.06
2nd - 1.63
3rd - 1.0
4th - .70
Old Nov 15, 2003 | 04:36 AM
billhelton's Avatar
Car: 85 Sport Coupe
Engine: 355ci
Transmission: TH-350
I had a Torsen in my 99SS with 495RWHP and it outlasted the clutch. I ran 1.6-1.8 6-' times with 4.10 gears and never had a problem with it.
Old Nov 17, 2003 | 11:21 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
i'm runnin a zexel torsen with my modded v6. no problems, i've run slicks on the car too, it works great. i pull 2.12 60' on street tires at the track. i've got 4.10 gears on the ZT unit also...the only thing is...you gotta either buy the split paddle to go inside the posi (to keep the axles out) or you gotta grind some teeth down a little on the ring gear. don't worry, i've heard of this being done before and it is what i did on mine and i have had no problems, you don't grind the teeth off, just down so that the paddle will slide past.
Old Nov 17, 2003 | 01:34 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I have a zexel torsion posi going in behind my 350. I will probably be running nitrous also. With your v6 you should do fine with a zexel posi. I know some guys that beat the crap out of theres and there good. Its the same posi that comes in 4th gens stock. I know a guy running 11's in a 02 TA with the stock gears and posi. I think you will be ok with it.
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
Scamo-2.8
May 20, 2016 07:01 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
