Pro-Topline Vortecs vs. pGM Vortecs & Flow
Old Jan 7, 2004 | 08:39 PM
9c1Caprice's Avatar
Theres a considerable amount of posts on this board concerning these two pro-topline heads.
This is the only post I found with any mention of an objective flow test. Link
::edit- pic wont attach- its the 6th post down on the link::
These numbers look pretty high and almost a 'too good to be true' number when compared to Chevy High Performance's data. It should be noted that the Stock vortec flow data is printed twice in their mag. The first time (that i saw) was in the much read GM Goodwrench Quest Part 4
compared to CHP cylinder head database flow #'s
Both of these flow tests were done on a 'westech' bench. But the discrepancy bewteen these two posted flow rates is mind blowing. One has a horrible I/E relationship, one good. One has much worse intake flow numbers, one better.
My question is: Though the flow numbers of Pro Topline heads look great and have seemingly amazing I/E relationship, How am I to pick between these two considering how arbitrary these flow numbers seem to be - even with the examples provided by CHP??
And then, how do you quantify BSFC and the other variables that work for power vis a vis cylinder heads. I need good below 5000 rpm torque with an efficient chamber to move around my car.
How's a guy to pick between the two and make the right choice??
Old Jan 8, 2004 | 11:40 AM
9c1Caprice's Avatar
Anyone?
Old Jan 10, 2004 | 05:10 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
You can't go wrong with Vortec heads for a good torquey street engine. Face it even Edelbrock copied them and then compare their now BEST head against them.
Old Jan 10, 2004 | 07:03 PM
9c1Caprice's Avatar
Thanks for the reply. You make a good point. Everyone is copying them and making good builds with them. Untill I see something more solid and concrete about these pro toplines, I'm going with the tried and true, proven factory pieces.
Old Jan 10, 2004 | 09:23 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Pro-Topline heads are usually more a race oriented than a Vortec's. For max power with supporting mods the Pro-Topline will be the best iron head. However, the Vortec's are excellent in their own right as mentioned above.
Old Jan 11, 2004 | 01:03 AM
9c1Caprice's Avatar
Race oriented- maybe thats it.
There are some problems with the stock vortec heads, such as the combustion chambers need to be cut on the intake port to reduce valve shrouding or to increase swirl and the exhaust port needs a little work.
Of course some of these modifications come at a price.
Were these modifications made to run with tradeoffs (there almost always are tradeoffs) to make the heads run at higher rpm's?
Vortec heads- good for apps under 5000 rpms and Pro's at a higher rpm band?
Or maybe youre talking about the casting's durability and screw-in studs good for higher horsepower/RPM applications
Old Jan 11, 2004 | 01:53 AM
OMINOUS_87's Avatar
Tall 5000 is more of the operating range, say 5800rpm-6000rpm.
For Vortec
Old Jan 16, 2004 | 06:50 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Depending on the rest of your intake system and cam is what determines the heads. The ported L98's have the best E/I ratio, but used they are about $500, so the price knocks them out.
For the cash, I'd pick the vortecs and have them ported in the chambers and exhaust, with better springs and the back cut valves.
Old Jan 18, 2004 | 08:25 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
And how much more money does it cost for all of that?
Old Jan 19, 2004 | 04:08 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
I have a set of both. The Pro-Toplines are more performance oriented. The factory Vortecs were originally intended for trucks and that's where my stock factory Vortecs reside...on a 400 SBC built for big torque in my Suburban. The Pro-Toplines pick up where the factory Vortecs stopped. I've found their improvement in flow is not much better. Where they shine is in the improved design. They already have screw-in studs (stockers are pressed), the spring pockets are already enlarged and the guides cut down (both necessary modifications for lifts over .480 on the stockers), improved water jackets for better cooling around the chamber, and much thicker deck surfaces which will accomodate a 45 cc chamber (stockers are pushing it at 58cc). If you intention is to put Vortecs on a milder motor with less than .480 cam lift, go with the factories. If your intentions are bigger, ProToplines...no question. They were built for the performance enthusiast.
Old Jan 19, 2004 | 08:11 PM
Abubaca's Avatar
I've read a lot about the Pro-toplines, but does anyone have part #'s?
Maybe I'm looking right past it, but I can't find 'em on the website.
Old Jan 19, 2004 | 08:39 PM
Abubaca's Avatar
....found it!
Old Jan 22, 2004 | 09:54 AM
9c1Caprice's Avatar
Thanks for the replies. Im reading alot about how the Pro-Toplines are better suited for high horsepower applications due to their improvements related to strength, i.e. thicker castings, screw in studs. However, I'm still looking around for a comparative flow and/or dyno comparison.
I see why people dismiss the heads as 'truck' heads. Weak stock springs, screw in stucs, etc. However, their Iron lt1 ports (flow better than aluminum lt1's) move air great up to .500 and have great mid lift flow numbers. Their contributions to good VE numbers and BSFC are well documented. This has been hashed out on here before, but its too bad there is no good a/b comparison between the two heads.
There is some discussion revolving around flow, but I guess there is no hard info on the subject. Ive been looking everywhere for some flow data. Furthermore, I really appreciate all of the discussion here on these two heads.
Thanks.
Old Jan 23, 2004 | 07:18 PM
r90camarors's Avatar
Engine: LO3;383tpi
I'm running the pro topline vortecs. I can't really compare them to gm vortecs or e-tech heads as I have never run those, but I am very pleased with the pro toplines. I have been interested as well in the flow numbers. What I like about the protoplines is that there was no machining needed for my cams lift (.510 w/ 1.5's) I'm pretty sure they are capable of at least .550" lift.
Old Jan 30, 2004 | 02:13 PM
Shagwell's Avatar
Car: projects.......
I'm putting together a +.040 350 for my roomates s-10 and we're using the Topline Vortecs. We went w/ them because of the improvements over the GM vortec's, plus I was really impressed w/ Topline's casting quality w/ my 200cc aluminums. He had them flowed and they were pretty well right on Pro's #'s, and where they were different they surpassed the #'s on Pro topline's website. I think they're an excellent head. Cost $420 delivered to my door, bare. Can't beat that.
...now to gasket match them and dropped this polished Crosswind RPM intake on top w/ that 535/555 hyd roller cam..
later, justin...
Old Jan 30, 2004 | 02:32 PM
wesilva's Avatar
Transmission: 200R4
Shagwell,
I'm finding the need for a custom pushrod length because of the increased deck thickness. Let me know if you have found the same.
Old Feb 4, 2004 | 07:34 PM
Pony Killer's Avatar
Car: 1986 Z28
Transmission: th400
i've been very impressed with my lightly modded factory vortec heads.. they've gotten me into the 11's with a well over 3000lb car, and poor gearing.
As far as modding to the heads i had the bowls blended, valve job, and a slight mill to them, using stock vavles.. including the price of the heads, machine work, all the hardware, and installation, with gaskets cost me 850 bucks.
I had no need for screw in studs. i'm running a comp XE 274 cam.. under .500 lift.. no super duper springs. so the stock studs are good for the time being.
one day i'll dig out the flow sheet again. was the bare heads, peak intake flow was 233 i belive. which is within a very little bit of what they did pre bowl work.. but all the below peak numbers significantly improved.
E/i ration at .500 is 72 or 74% i belive.. it stays in that range through out.
i'd recomend them
Old Feb 5, 2004 | 01:46 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
I suppose Stevie Wonder and Ray Charles ported those Vette heads, considering both sets I have were flow tested at 250cfm+ at 0.500" lift.
Old Feb 5, 2004 | 02:57 PM
Dustin Imports's Avatar
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
Ive been doing alot of reading on vortecs lately. Pretty set on getting them i thought. but are you saying the stock l98 heads (i have) will flow as good or better when ported? Still learning here. Not fully understanding
Drew
Old Feb 5, 2004 | 04:22 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I'm sure I'll catch hell for stating the basic facts about my heads, so I'll just post this article:
Attached Thumbnails Pro-Topline Vortecs vs. pGM Vortecs & Flow-vortecflow.jpg
Old Feb 5, 2004 | 10:18 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I've had stock 062 vortec's, the pro-topline vortecs, and a set of Edelbrock E-200 vortecs .
I've had all of them side by side on my workbench and compared them.
From best to worst:
E-200's-due mainly to bigger runner size, a better looking exhaust port, and weight reduction. More than enough to feed a 525 horse 383 (although they still needed a light cleaning with a sanding roll).
The pro-toplines come in second, they looked a hell of a lot better than the stock vortec's. Plus they come with alot of perks that you have to pay for in machining on the stock vortecs. Good to 525-550 lift depending on springs and whether you're running hydraulic lifter or roller lifter cam.
The stock vortecs are a nice budget head. If you're building a 350 or 327 with less than 480 lift cam they're great.
I intended on using my pro-toplines for my buildup but had the e-200's dumped in my lap so to speak. Otherwise I'd use them without hesitation. They are still for sale or possible trade parts I need.
The stock vortec's I already had and sold.
Pac J
May 17, 2020 10:44 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
dusterbd
Sep 29, 2015 08:40 AM
monte87cortez
Sep 26, 2015 08:10 PM
