DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
help me pick dfi
Old Jan 11, 2004 | 11:58 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
help me pick dfi
i am looking at going dfi. this is what i want
i need
tcc
and fuel injection control
i was looking at either the gen 7 from accel and the commander 950
what else do you guys suggest i am trying to set this thing up on my 87 tpi setup for under 1300 thanks guys
Old Jan 12, 2004 | 07:23 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
The Gen 7+ does TCC and a bunch of other stuff that I don't believe the 950 can do, but you'd have to work hard to find one for ~1300.
Are you geared more toward street driving or just racing -- or do you want to be able to drive your car to the track, race it, then drive home? Will you ever be using Nitrous or getting into a blown application? Do you want to run in Batch or Sequential Injection? Are you going to tune it yourself, or pay someone to get it running for you?
Both the Holley and DFI are good systems. You need to decide which one suits you better.
Shameless Plug --> Check out the 96 TT Impala in this month's Hot Rod for some of the potential of the DFI system.
Old Jan 12, 2004 | 10:54 AM
c4boom's Avatar
Engine: l98 and lo5
it will be 80% street 20% track and at some point will be geting blown. all i want is the ecu and wireing harnes i have a HSR yet to be put on. and at som point i will begoing to eather a th 400 or a well biult 200 4r have 700 r4 now
Old Jan 19, 2004 | 11:16 PM
biggtime's Avatar
Sorry about this thread highjack but....
When are we going to be able to datalog without the laptop hooked up? I read that article when will all of that stuff be available to us non employees? Will that just be a new *flash* or a different unit?
Old Jan 20, 2004 | 06:47 AM
aDFIguy's Avatar
Car: GTP
Engine: L67
There will be a version 4.0 upgrade to the ECM announced within a few weeks. It includes a firmware update, and a new version of the tuning software. Here's some of what is added:
GM LS1/LS6 compatability -- Specific kit that plugs in to stock cam/crank/coil connections (available now).
Network tuning -- connect to an ECM over the internet for calibration purposes.
New Dataloging -- NOT standalone yet, but easier to work with.
Nitrous Controller -- Many changes, new stage 3 controls, shutdown timers, High resolution retard maps, and more.
Wideband O2 sensors -- can use anyone's sensor package that can be programmed to have a linear output 0-5 volts == 10-20 A:F ratios.
Alarm input that can generate an error code and optionally shut down the engine after a period of time from when the input is activated.
Launch Mode, designed specifically for launching a drag car. Alternate Spark and A:F maps, integrated boost builder, and delay/shutdown timers.
Power Enrichment Mode -- Switch to alternate A:F map above a threshold set via %TPS vs. RPM.
HEGO A:F Mode -- Better closed loop control over a:f ratios other than 14.7:1 with a HEGO sensor.
There's more, but it's too much to list here.
Old Jan 20, 2004 | 07:53 AM
biggtime's Avatar
Sounds good, I'll be waiting for the annoucement.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
92projectcamaro
Sep 29, 2015 07:07 PM
efiguy
Sep 27, 2015 01:30 PM
