oook.....Drums dont work after gear swap
Old Jan 30, 2004 | 07:55 PM
SeanTimothy's Avatar
yes i bled them.....15 times......i took the lines loose at the drums....nailed the brakes, fluied shot 15 feet.....no blockage....
if i pump the brakes a good 6 times hard they finally work....but ...if you nail them once...nothing happens....the pistons in the drums wont move.....unless i pump the bejesus outta the brakes....any ideas??
this happened when i finished up putting my rear on.....im not a brake pro.... help!
this happens o nboth drums....it isnt just one..
Old Jan 30, 2004 | 07:58 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Re: oook.....Drums dont work after gear swap
If only there was a Suspension / Chassis / Brakes Section to this site
Old Jan 30, 2004 | 07:59 PM
shush!! i didnt see that! ... haha...
Old Jan 31, 2004 | 07:25 AM
ede's Avatar
ede
do you have the shoes adjusted to fit the drum?
Old Jan 31, 2004 | 08:48 AM
ok i fixed em, just had to bleed them from the bleed nipple on the drums.....
Old Jan 31, 2004 | 10:01 AM
ede's Avatar
ede
that would be the bleeder screw on the wheel cylinder
Old Jan 31, 2004 | 11:51 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
pfft brakes are over rated anyway.. who needs em.. I had a honda beater that needed a master cylinder for about 6 months that I just didnt feel like wastin money on.. all ya need is a 5 speed and a parking brake really.. doesnt exactly stop on a dime but it makes driving so much more intresting.. my favorite way to slow that piece down quick was to throw it in first gear at any speed and use the friction material on the clutch disc as my brake...
hectre13
Dec 11, 2023 08:14 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
