Post pics of Suspension mods
Old Feb 8, 2004 | 03:51 PM
85camaro350's Avatar
Car: 1985 Camaro Z28
Engine: 350 carb
Transmission: TH-700-R4
Just as the title sais
Old Feb 8, 2004 | 04:09 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Though I've made some additions (note my sig), here are several from my 85 IROC.
JamesC
Old Feb 8, 2004 | 04:11 PM
JamesC's Avatar
Another.
JamesC
JamesC's Avatar
Last.
JamesC
Old Feb 9, 2004 | 07:04 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Old Feb 9, 2004 | 07:32 AM
MdFormula350's Avatar
suspension mods are the hardest to take pics of all the ones i have are on my cardomain and its not many.
Old Feb 10, 2004 | 07:34 PM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
DEWEY316
where did you get those alloy mounts? as soon as you reply, im gonna order them. only thing im missing is those and the bump kit tie rods.
Old Feb 10, 2004 | 09:21 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Kontrax,
Those specific mounts were made my Karl Hunter of HunterMotorsports. he made i beleive 20 sets a few years ago. you can get basicly the same the same thing (actualy has a couple of advatages vs the ones i have) from Spohn.
http://spohn.net/product.cfm?productid=1452
if you REALLY like mine they only have a couple thousand miles on them. if you order me a set of spohns, i'll part with mine.
Old Feb 11, 2004 | 12:33 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Originally posted by Dewey316
Kontrax,
Karl shoulda taken out a patent...
Old Feb 11, 2004 | 01:39 AM
ebmiller88's Avatar
Eibach, 1LE, ES poly, KYB, EBC, Earl's, Hotchkis.
Old Feb 11, 2004 | 01:40 AM
ebmiller88's Avatar
Eibach, KYB, Earl's, 9 bolt posi...you get the idea.
Attached Thumbnails Post pics of Suspension mods-rear-axle-suspension-parts.jpg
Old Feb 11, 2004 | 06:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes he should have.
and now i am not so exclusive either, anyone have have a set that is very similar
Old Feb 11, 2004 | 10:46 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
yes he should have.
Ah....but we have THE originals...and I believe that Karl isn't going to make any more.
Only 20 of us have the original Hunter Motor Sports camber plates....the ones that started it all. That's pretty exclusive.
Old Feb 11, 2004 | 10:51 AM
Dewey316's Avatar
Car: 1990 Camaro RS
besides, ours look more hardcore, with the exposed TIG welds and all, spohn look too pretty
Old Feb 11, 2004 | 12:00 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
No pictures, but....
Kyb-gy2 struts
34/24mm GM swaybars
ES poly Endlinks
ES poly swaymounts
Unbalanced Eng. Panhard
TDS VR1 Wonderbar
Spohn bare SFC's
replaced most linkage with stock replacements
Looking at getting...
TDS VR2 WB
Replace control arm bushings, prob ball joints at same time.
Later then sooner, everything they make for this car
Old Feb 11, 2004 | 12:33 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You forgot ping pong table.
Old Feb 11, 2004 | 04:21 PM
Frains90RS's Avatar
Car: 1990 Camaro RS
Engine: LO3: 305 TBI
Axle/Gears: 1997 Trans Am rear w/ posi -3.23
Nothing fancy just the bare essentials.
KYB, Eibach, Spohn.
Add corresponding parts to the front, along with 34mm front and 24mm rear sway bars. Well, heres the pic. All Moog linkage and ES bushings.
Old Feb 11, 2004 | 06:14 PM
Kontrax's Avatar
Car: 86 Camaro
thanks man, im gonna get those mounts. ill post up a pic sometime soon of my chassy. all BMR. i changed everything there is to change or add. only thing i couldnt do is put a STB on because of the blower oh yeah, and i dont have a tubular k member eather...maybe this summer.
Old Feb 11, 2004 | 07:36 PM
BORLAZ06's Avatar
Old Feb 11, 2004 | 08:13 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
BORLAZ06
So who did you go with for your tubular stuff. It looks like PA racing. Am I right?
Here is a quick shot of my rear suspension with various spohn stuff and springs.
Old Feb 11, 2004 | 09:35 PM
BORLAZ06's Avatar
yea, paracing kmember.
Old Feb 11, 2004 | 09:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You should do a weight comparision to see how much the tubular stuff saves you over the heavy and bulky stamped stuff. I would love to see that.
Old Feb 11, 2004 | 10:43 PM
ebmiller88's Avatar
Borla, is that how BIG the tubes are on the Bilsteins? They look about 1" thick? Am I seeing things? Please post part numbers..
Ed
Old Feb 11, 2004 | 11:14 PM
BORLAZ06's Avatar
I don't know the exact size of the tube.
Heres the part #'s
Shocks - B46-1021
Struts - S36-0201
And I'll see if I can find a way to weigh the K-members to find the weight comparison.
Old Feb 11, 2004 | 11:25 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Hey Shifty, is that panhard in the pic a spohn piece? Looks differant than the pics on his site. The mount on the bar looks like it goes together same as the rod ends only it's a poly mount. Looks like I could attach it in place of a rod end and make my full spherical rod ended bar a combo setup.
Old Feb 12, 2004 | 07:25 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yes it is a spohn piece and it is the basic single adjustment one. It has a poly end on the other side (out of the pic) and a rod end on the driver side (axel side). I'll see if I can dig up a better pic.
Old Feb 12, 2004 | 05:35 PM
ebmiller88's Avatar
Nate, where'd ya get the Bilsteins? Just curious.
Ed
Old Feb 13, 2004 | 08:06 PM
BORLAZ06's Avatar
SHOX.COM Ed
Old Feb 14, 2004 | 01:12 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
heres a pic of mine
Old Feb 14, 2004 | 10:51 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Dont have any pictures, but this is what i do have:
KYB Stuts up front and McPhersons in back (ok)
Hotchkis Lowering Springs (great)
PST Polygraphite Bushings everywhere (great, but a PITA to install on the A-Arms)
TDS Wonderbar (great)
New tie-rods (?)
Stuff Im getting VERY soon:
Edelbrock Panhard Rod, Stut Tower Brace, and Trailing Arms and maybe their Torque Arm
And either Hotchkis or SPOHN Subframe Connectors
IROC Swaybars
My L03 isnt very quick, but it handles like no other!!
Old Feb 15, 2004 | 10:54 AM
ebmiller88's Avatar
Shox....Thanks Nate.
Ed
Old Feb 15, 2004 | 01:19 PM
Camaro_nut's Avatar
Don't have pics either but here's my evergrowing
list:
Spohn chrome moly adustable Panhard rod
Spohn chrome moly LCAs
BMR bolt on LCA relocation brackets (will be
reinforced with weld beads during/after drivetrain mods)
Spohn sway bars
Everything poly. bushings
Hotchkis coil springs ( 1" drop)
KYB GR2 front struts
KYB gas-a-just rear shocks
Global West steering brace
Edelbrock 3 point strut tower brace
Toyo Proxes directional tires
Coming soon ( this spring/summer...fingers crossed!) :
Spohn adjustable torque arm
Spohn cross member for T-56
Spohn driveshaft
Spohn adjustable steering brace
Old Feb 15, 2004 | 01:21 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
list:
Spohn sway bars
Spohn driveshaft
What does the steering brace really do for your suspension?
Old Feb 15, 2004 | 01:28 PM
Camaro_nut's Avatar
Prevents any deflection/flexing during hard cornering
in the lower front end of the car. Does like a strut tower
brace does, but instead of reducing top end flex on
corners or even hard accel, it reduces the bottom end flex.
Also, does a great deal to keep the steering box in place.
Reduces flex is the main purpose!
EDIT: I also noticed that my power steering doesn't
groan/whine in hard turns anymore! So, it's a real
benefit just to help with the steering box from flexing!
Old Feb 15, 2004 | 01:53 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
I checked global wests and spohn's site and didn't see them listed for sale.
Old Feb 15, 2004 | 02:05 PM
Camaro_nut's Avatar
Yes they do! Look here for Spohn's:
http://www.spohn.net/category.cfm?categoryid=1078
Old Feb 15, 2004 | 02:11 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
OOoooooh, the "wonder bar" I was gonna say when u told me what it did I was like "Man, that sounds a lot like what the wonder bar did." lol. ok thanks.
Old Feb 15, 2004 | 05:59 PM
Car: 91 Formula
What is the purpose of the "adjustable" wonder bar? What is the benefit to that?
Old Feb 15, 2004 | 06:11 PM
FLYNLOW92rs's Avatar
Here are the dropzone springs......
doesn't look like this anymore, the picture is kinda old.....
Old Feb 16, 2004 | 05:26 PM
Camaro_nut's Avatar
Yeah, "The Wonder Bar" aka "steering brace" or vesa versa...
You got the idea now. They are both the same thing.
Now go get one. You will feel a difference.
Old Feb 16, 2004 | 05:28 PM
Camaro_nut's Avatar
Please click on this link and read for details! :
http://www.spohn.net/product.cfm?productid=1392
EDIT: here is the description right from Spohn.net:
Is this adjustment a gimmick? Honestly, a resounding no. We built one of these after a serious brain storming session just to see what it would do. We were quite honestly amazed at the crisp steering response it provided, so we decided to offer it as an option. What the adjustment allows you to do is place pre-loaded tension onto the front sub frames. It makes for a very tight front end!
I think I should be the posterchild for Spohn.net! LOL
I am like "pushing" all of there products here!
Old Feb 16, 2004 | 07:32 PM
Kontrax's Avatar
Car: 86 Camaro
adjustment can also align your rearend.
Old Feb 16, 2004 | 07:49 PM
Camaro_nut's Avatar
This is true, and necessary if you had lowered your car!
I had to get an adjustable panhard rod after swapping
in the lowered coil springs. One side was sticking out
almost 2 inches more than the other.
As far as adjustable lower control arms, it is mainly
for more traction when you lenghten the LCAs. But,
can still be used to help correct any rear end alignment
issues (dogtracking). Although, our Hunter Alignment machine
at my work does not show any adjustments for rear, because
it is fixed anyways. Most RWD vehicles with fixed rear
suspensions usually don't have any adjustments. But
that's usually just pickup trucks/some SUVs. Some RWD cars
have adjustments. It all depends on make/model/year,etc.
It varies so much.
Kontrax,
My friend gave me the thumbs up for using his garage
for my GMPP 350/ T-56 swap! Coolness...! I may have told
you already, but I had to make sure with the guy about
it again. I'm excited! I haven't done any major performance
mods like this in years!
Old Feb 16, 2004 | 07:53 PM
Camaro_nut's Avatar
Originally posted by DARCOM
heres a pic of mine
That's a sweet looking custom exhaust!
Old Feb 17, 2004 | 08:03 PM
Kontrax's Avatar
Car: 86 Camaro
you use hunter too? heh. the adjustable panhard is also good if you use a different wheel. i used a different offset 15 inch wheel with the lift on my car and had to re-align the rear. i hope all goes well with your swap i wanted the stick myself, but im pushing big power and i like the ease of auto. i have a GTA with a stick im going to work on next though. 1st thing is a total rebuild on the suspension. i plan on sticking with BMR products. im impressed with all the stuff i got with them before. to bad they dont make 3rd gen k members.
Old Feb 18, 2004 | 02:38 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
my spohn sfc's... i've also got a 34 mm front sway bar with energy suspension polyurethane bushings and endlinks, and a wonderbar from the junkyard, but i've only got pics of the sfc's...
Old Feb 18, 2004 | 07:26 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
LPW Girdle and Axle Tube Brace Kit
Not really suspension but ... since most people don't have this ...
Tim
Old Feb 18, 2004 | 11:25 AM
Car: 86\92 Mutant
Engine: 355CI 430HP
Re: LPW Girdle and Axle Tube Brace Kit
Tim
That's a very nice piece....
Old Feb 18, 2004 | 12:25 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
is that to strengthen up the rear axle? never seen that before...
Old Feb 18, 2004 | 01:42 PM
TRAXION's Avatar
Yes.
Tim
