My Exhaust Clip...
Old Mar 27, 2004 | 02:24 PM
NEEDforSPEED's Avatar
My Exhaust Clip...
Heres a Clip of my Camaros exhaust, the MIC was about 15 feet away from the tailpipes... the highest it was revved up to was 3,500rpms
enjoy
Click Here...
Old Mar 27, 2004 | 02:40 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
lol..sounds nice....the idle couldnt help but remind me of a desiel truck though *shrugs
Old Mar 27, 2004 | 03:19 PM
Sounds better if you got a subwoofer, but its even better in real life
Old Mar 27, 2004 | 03:57 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Hopefully I'll have mine to share tonight!!! Like hows sounds to man.
Jason
Old Mar 27, 2004 | 07:22 PM
Intensity_Z's Avatar
Car: 84Z/ 87 S-10
Engine: 355/350
Transmission: th-350/700-r4
sounds pretty decent, but it does crackel alot, was the motor cold when you were revvin on it?
Old Mar 28, 2004 | 10:42 AM
i let it warm up for a long time, around 8mins...
frist start up this summer, since last fall
Old Mar 28, 2004 | 02:35 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
yea the crackels isnt really good but other than that its sweet
Jason
Old Mar 28, 2004 | 05:33 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My flowmaster exhaust only crackels when it is cold.
You running a cat?
Sounds good though
Old Apr 1, 2004 | 11:32 AM
Car: 84Z/ 87 S-10
Engine: 355/350
yeah my flow's crack when its cold or if i rev it to about 5500 rpms but i'm not running a cat on mine
Old Apr 1, 2004 | 03:56 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
yea if u dont have a cat (which NEED's doesn't) then ur almost always goin to crackel...sounds good on some and like crap on others.
Old Apr 5, 2004 | 12:56 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
OK, here's my experience with the crackling or popping noise. First off, cat is hollowed out. It did crackle when I had my smog pump hooked up, but when took the belt (to the pump off), it made no crackling whatsoever. When it was time for inspection, I put the belt back on, it went back to crackling, and once again, when I took it off, it no longer crackled. Now it does a little bit since I do have a small exhaust leak. All this has led me to believe that any outside air (with oxygen) causes the popping due to burning unburnt fuel that has gotten into the exhaust. This makes sense to me that this is the purpose of the smog pump... to lower emissions by completely burning all the fuel before it goes out the tailpipe. Now I don't know if this is a correct assumption, but just what I have reasoned.
Old Apr 12, 2004 | 07:05 PM
Matt Parsons's Avatar
Car: 86 Iroc
Engine: 357 DFI N20
Transmission: 700R
Is that a stock motor?
Old Apr 25, 2004 | 05:53 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
what exhaust is that
Old Apr 29, 2004 | 07:34 PM
flowmaster,
Old May 6, 2004 | 03:06 PM
bubbakutz's Avatar
Engine: LG4
the flowmaster dual cat back set up?
Old May 6, 2004 | 05:32 PM
1 cat, back
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
