Where Do These Brackets Go
Old Apr 22, 2004 | 02:48 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
ok so i am finishing up my headers install and now i can't remember for the life of me how the 4 brackets that hold the AC and PS pump go back on. does anybody have any pics of how they go back on. please...i want to finish this up once and for all.
Old Apr 22, 2004 | 05:52 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Hope this helps.
Old Apr 23, 2004 | 02:33 PM
chio987's Avatar
Engine: 305 4bbl HO
it gives me an idea of how it goed, my only thing is i am using the AC top bracket too, it lookas like u used the one but i'm guessing it is just as a spacer for the other brackets. idunno
Old Apr 23, 2004 | 03:44 PM
chio987's Avatar
Engine: 305 4bbl HO
i was looking at it again, and i DID cut the right side didn't I????
i mean if i cut the other side off it doesn't look like it would fit..the side faces us is the side that faces the block and the left side would be pointing to the back on the car.
Old Apr 23, 2004 | 07:34 PM
chio987's Avatar
Engine: 305 4bbl HO
anyone????
Old Apr 23, 2004 | 08:19 PM
there is a spacer to seperate the two and I believe there is a spacer that seperates from the front header/exhaust manifold bolt too.
Old Apr 24, 2004 | 11:48 AM
chio987's Avatar
Engine: 305 4bbl HO
so can anyone tell me if i cut that bracket wrong??
Old Apr 24, 2004 | 10:08 PM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
sorry dude, you cut the wrong part of the bracket. The other side has to be chopped off in order to clear the header pipe. The part that you did cut off would then get bolted with a spacer, then the header, and then into the block - a big sandwich. If you have access to a welding machine, weld the bracket back up. If not, your not gonna have your power steering, or if you can manage to tighten the other bolts down, it will most likely end up going loosing up over time. The same would go for the AC, because the bracket helps support the compressor. I took a few pics of my setup, I shoulda took more time looking at how much meat to take of the bracket but I was in a hurry... Its fine though and works perfect.
Old Apr 24, 2004 | 10:13 PM
chio987's Avatar
Engine: 305 4bbl HO
LOL, o dam, o well...i don't think i need it anyway, the AC will still have 3 bolts and it's not even hook up right now, so o well
Old Apr 24, 2004 | 10:14 PM
Car: 84 Z28
Engine: 305 HO
That was a pretty fast reply, do you need any more pics or anything? Id be glad to help if I can...
Old Apr 24, 2004 | 10:40 PM
chio987's Avatar
Engine: 305 4bbl HO
well if i do run into problems with stuff coming loose can i get that one bracket from a parts store?? or do they come in a kit or somethin?
Old Apr 24, 2004 | 10:43 PM
Car: 84 Z28
Engine: 305 HO
I doubt autoparts store. Junkyard, ebay etc... Save your old stuff and just weld it back together... or just figure out the dimensions and everything, and just make a new bracket... I dont know if you have the tools or capabilities for this, so your prolly better off going grave digging in the junk yard.
Old Apr 24, 2004 | 10:59 PM
chio987's Avatar
Engine: 305 4bbl HO
ya i'll end up going to the junkyard if need be. thanks man.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
