V6 still not running
Old May 9, 2004 | 08:26 AM
jwisse1's Avatar
Car: 1987 Firebird
Engine: 2.8 MPFI
I checked the spark plugs the were not fowled, but I replaced them anyways. I checked the injectors the are working. the next thing I am going to check is the timing. Any other suggetions are welcome.
Old May 9, 2004 | 10:48 AM
ChaosRanger's Avatar
Car: 1984 F41 T-Top
Transmission: 5 speed
From the searches that I have read through the most common problem was a lose wire. As stated from other people in your past post check all wires even the starter below.
Check to see if your distributor cap is lose or if your distributor is rotating.
Spark, make sure your spark is an intense white/blue and not yellowish. Yellowish means weak coil, bad wire(s), or battery needs charging.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
