Oooo Weeee!!! Parts Parts And More Parts!!!!
Here's all my new stuff...should be up and running in a week or two
- Rims are Boyd Coddington Smoothie 2's...17x8 up front, 17x10 in the rear wrapped in Yokohama AVS ES100's
- Rear is a 9 bolt w/ 3.27's and LCA Relocation brackets welded on
- Spohn Torque Arm w/ Rod ends
- Spohn Shock Towers
- Spohn Sway Bar Kit
- Poly all around
- Del A Lum front A-Arm bushings
- Bilstein HD Shocks/Struts w/ Eibach Pro Kit
- Spohn Poly/Rod LCA's
- Spohn Adjustable Poly Panhard Bar
- Polished LS1 Aluminum Driveshaft
- Holley In tank Extra Flow Fuel Pump
- ES Poly Trans Mount
- TDS Wonderbar
- Baer Track and Sport kits...slotted/drilled/zinc rotors w/ Polished calipers all around
- Wilwood Proportioning Valve
- Royal Purple Fluids
- Turtle Wax Ultra Gloss Wax and Detailer
(threw that in there for the helluvit)
-NOTE: Everything is 4130 Chrome Moly
- Poly all around
- TDS Wonderbar
(threw that in there for the helluvit)-NOTE: Everything is 4130 Chrome Moly
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Nice ! I guess the SweetRide will be getting sweeter LOL
very nice. classic choice on wheels, good width too! your going to love the hd's and pro-kit....the right choice, bilstein sports are for the sportline springs.
beautiful driveshaft as well..........looks like a very nice set of parts!
Car: 1992 Camaro Z28
Transmission: 5spd.
"Oh what fun it is to ride in a thirdgen"! Man your so lucky, take some pic's of the install. Can't wait to see it once it's all said and done!!! Pic's, Pic's, and more Pic's~~~:hail:
Thanks for the compliments guys...now I have yet ANOTHER hold up...Baer sent me the wrong backing plates for the 9 bolt...geez...no body knows how to do their job these days
Hey, w/ the Sport kit, are you suppose to get the E-Brake cables w/ it? AND, do both sides have an E-Brake setup? The cables for the E-Brake didn't come w/ mine, and both calipers have the E-Brake setup...
Edit: Kandied: Touring Kit is going on the front (2 piston)...Sport on the rear (single piston)
Switch 'em around...I'm gettin' confused w/ all these parts already...lol
Ok, I just found out...I got the wrong backing plates from Baer, PLUS, they didn't send me the Emergency Brake Cables...and yes, I answered my own question, both calipers require the E-Brake cables...Bastards I tell ya!
i was going to say, in your list it says track (13" 2 piston kit) for the front and sport (12" 2 piston kit) for the rear.....i was about to say wow. with 2 piece rotors that would be a nice way to spend 4,000.
so you got the 12" 2 piston sport kit up front and a stock pbr disc brake setup for the rear and the bracket that extends the mounting to hold a larger baer 12" rotor in the rear?
I got the Sport up front cuz the Track wouldn't clear my rims...12's should be sufficient enough, plus they'll look good behind the Smoothies
Touring in the back b/c not much is needed in the rear anyway....I didn't want to get a huge kit for the back...stock from Baer will be fine...just got the kit to match the front
looks good, i agree about the front....in all truth i love the looks and power of the 13 but the hassles it incorporates aren't always worth it. it's rather difficult since you can't bolt a smaller wheel on them so i can't even align the 18's i have.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
umm, unbolt caliper.
yank rotor off.
put 14" steelies (or whatever) on.
align car.
slip rotor back on, bolt up caliper and put the 18s back on.
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I love those polished strut tower mounts more than anything you have pictured
But I'm kinda biased toward liking them
Car: 87 IROC-Z28
They are available from Spohn Performance for $350 per set.
http://www.spohn.net/product.cfm?productid=1452
Car: 87 IROC-Z28
Originally posted by SweetRide45
Alloy...
I wonder why you'd like them so much??
Alloy...
Car: 87 IROC-Z28
If you are curious as to what benefits of these mounts are, read the post from
vsixtoy in this thread. He explains is very well.
https://www.thirdgen.org/techbb2/sho...33#post1848133
Engine: 385 HSR.....LS1
SWEET!!!! whats all this going on?
Wishmaster's87IROC:
'90 Firebird...can't really call it a "Firebird" anymore...b/c it's totally custom, and as you can see by the parts...KILLS WS6 Performance Package...lol...So, it has to surpass the Firehawk...just don't really know...
Car: 1999 Saturn SL2
Engine: 4 cylinder
Wow, I envy you. Great parts you have there.
Let me know when you how much of a difference you feel when you get all that stuff installed. I want to do a similar suspension upgrade (if I can in this lifetime).
:hail: :hail:
:hail: :hail:
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Originally posted by Spdfrk1990
Now all im thinkin is wheres the roll cage.
I'm just being a wiseass. ddn69: No loan needed. I had the cash, and it's now paid in full
About to do another 6-8G's for the rest of the drivetrain, then I think I'm pretty much maxed out on what to do to her (well, as much as I know of NOW at least) hehe
About to do another 6-8G's for the rest of the drivetrain, then I think I'm pretty much maxed out on what to do to her (well, as much as I know of NOW at least) hehe Where did you get your drive shaft i really need one but dont know which 1 to get. Does anyone know anything about the lingenfelter aluminum peice. Im about to put alot of those parts on my car also some i alrdy have.
Spdfrk1990: It's all installed. I don't have pics of underneathe yet, but the pics from when I took it out are here:
Finished Pics
Sticks to the ground like GLUE
Finished Pics
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
thats insane. You been saving up for a while or u a drug dealer? LOL Just kidding. You gonna put an insane engine in there or what? You daily drive it or garage it?
Nate
Nate
ddn69: Daily cruiser that's garage kept. Never seen the rain (only when gotten caught in it) and never will see the killings of winter. I'm either doing a built up 350, or a bored/stroked 383 this winter. Should be the finishing touch
