project 82LT1 goes to the dyno..again
Old Jun 23, 2004 | 10:29 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Hello,
been a while since I posted.. going to grad school, getting married etc..
the LT1 has been running fine for 17k miles and it became time for a change.. it ran 13.4 @ 104 in bolt on mode, but I wanted a bit more so this weekend I put on a set of ported heads by Lloyd Elliot and his LE2 cam...
Here is the dyno graph after computer tuning at carolina auto masters.. the car came in with a poor mail-order tune at 351 rwhp, 341 tq.. after tuning the car pulled a very repeatable 372 rwhp and 360 tq... hobbled by edelbrock tes headers, I need better exhaust! Texas gunning for you buddy
Old Jun 23, 2004 | 11:04 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Wow great numbers. You should be in the 12's by now.
Old Jun 23, 2004 | 12:05 PM
FLYNLOW92rs's Avatar
What are the list of mods to the LT1?
Old Jun 23, 2004 | 12:36 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
12's? With some slicks thats some easy 11's.
pasky's Avatar
He just told you.
LE (Llyod Elliot) Heads (AKA Port and Polished LT1 heads), and a LE2 Cam (Llyod Elliot custom grind to match the heads )with headers and a PCM tune + cutout.
Lloyd rocks, he is a damn good porter and he is right here in Texas about 30-40 minutes from dallas. He can get flow numbers up to .180 out of stock lt1 heads and up to .200+ out of lt4 heads. He also makes custom grind cams after flowing the heads to match them up for some unbeatable prices, I believe his stage I is just about $1200 with a cam. Llyod rocks!
Old Jun 23, 2004 | 01:11 PM
STOCK or with minor Bolt-ons.....
Old Jun 23, 2004 | 01:21 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
13.4 @ 104 was with edelbrock headers, borla catback, electric water pump, street tires, 52mm tb, 3/4 tank of gas, 3395 llbs with no driver..
in that trim it dynoed at 288hp and 328 tq..
I have always thought the true measure of a car was to run it exactly as it sits on the street, and as such I do NO special prep for the track, not even to warm the tires..the car is built for everyday driving, handling, stopping and going.. the goal was to scare a few C5s into thinking they may have engine trouble..
the current setup it just dynoed with is:
LE2 billet cam in the 230s intake 240s exhaust, on a 110 lsa...
the heads are fully ported with larger 2.0/1.56 REV valves, CC 987 springs, Gm guideplates, and Lloyd Elliots port job (Do a search for him on CZ28.com)
Pasky you are right on, flow numbers are in the high 260's intake and high 180s exhaust..
Thunderracing hardened pushrods
CC Comp R lifters
CC pro-magnum 1.6 RR
I slightly sand rolled the ports on the intake..
the exhaust is Edelbrock TES, highflow Cat, and Borla Catback..
The blue number is uncorked
the number below through the muffler
the first number is what I came in through the door with surging and idling like crapola..
That is it.. if it wasn't for this board I would still have a carbed 305..
Old Jun 23, 2004 | 06:11 PM
Originally posted by pasky
He just told you.
AND the list of things he just mentioned.....
Good job with the car and numbers, interested to see what other mods are in the future, have been following it for while....
Old Jun 23, 2004 | 06:22 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
[i]
Good job with the car and numbers, interested to see what other mods are in the future, have been following it for while.... [/B]
Thanks, I don't really want to run longtubes so I think some 1 3/4 in SLP non-air shorties may be in order.. I certainly found the limit of the TES system.. the cat well, it will look normal.. I feel rather good that my N/A numbers are close to your N/X numbers on an LS1.. though your torque blows me to pieces
Thanks again for following the mods, I really wasn't sure if anyone was paying attention.. I pretty much just took ideas from here and there and looked here for motivation and applied it to what I wanted.. I am usually too busy to be a consistent poster but will finish my site soon and get on TexasLT1s swappers registry..
Old Jun 23, 2004 | 06:23 PM
pasky's Avatar
You mean just the 1.6 rr's and lifters?
Old Jun 23, 2004 | 06:25 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Very nice. :hail:
Old Jun 23, 2004 | 06:41 PM
Should be able to clean house on the stock LS1's without many problems...
You just about convinced me to go the LT1 route since you had a nice clean install, but the deal fel through...
I'm assuming by you mentioning your "n/a numbers" that you have plans for a power adder in the future.....
Old Jun 23, 2004 | 06:58 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Looks clean man!! Once I get mine runnin' in Kitt, I'll be adding a set of, either LE2 heads of Trickflows..
Old Jun 23, 2004 | 07:03 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
No, I won't do any power adding to this motor.. stock bottom end would be pushing it.. though the next LTx will be 383 based with bigger heads and a custom cam again.. though not until this one gives up the ghost.. for now I will be happy to squeeze some more hp out with headers later on..
I tried to keep the install as clean as possible.. but when I started the swap the conversion motor mounts and tranny mounts for LS swaps weren't available.. if they had been, there would be an LS engine with heads and cam getting dynoed.. I went with what I knew I could do with a minimum of problems..
LS engines have the best induction system.. though their flow numbers will knock 23 degree heads silly
not sure if I mentioned either, the RA2 hood is gone now, just a stock cowl flat hood is on now.. I like it better..
Old Jun 23, 2004 | 07:30 PM
Sad to see it go, looked good on the car...
Old Jun 23, 2004 | 07:39 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
It didn't fit right ever.. even after four hours or so of tweaking..
it was cut to sit better on a car with gfx late 80s on up..
the cowl hood actually works well for me, I went CAI and relocated the battery to the back, car hooks better.. but can still make the tires beg for mercy
just for giggles here is a pic of a Lloyd Elliot intake port..
Attached Thumbnails project 82LT1 goes to the dyno..again-intake-port-resize.jpg
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
92projectcamaro
Sep 29, 2015 07:07 PM
Vincent135
Sep 28, 2015 10:50 PM
