Fuel pump that can handle a LT1 for thirdgens?
Old Jun 25, 2004 | 12:32 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Anyone know which walbro pump to get? I want to keep a spare in the garage just incase the V6 pump decides to take a crap. The car has been running lean and I havn't replaced the fuel filter but if it continues after I do so, I may replace the pump. I don't need an overkill race pump, but definatley one that is at least at the stock LT1 pump range or better and needs to be a direct replacement. Thanks.
Old Jun 25, 2004 | 03:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Walbro 255 high pressure. The 190 and base 255 units can suppoort serious power levels but I cannot remember what PSI they can maintain.
Old Jun 25, 2004 | 04:07 PM
pasky's Avatar
May be 52-60 PSI. Wheres the cheapest place to get them shifty? I've checked thunderracing and summit and they carry holley unless walbro is the samething.
Old Jun 25, 2004 | 05:00 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
The Holley one is the same.. it says Holley 255lph by Walbro on the casing.. same one I am running.. just has a different name on the box..
hope that helps
Old Jun 25, 2004 | 05:06 PM
pasky's Avatar
Anyone know where to get the best deal? Is this a direct replacement? Don't have to change the wiring harness or splice in anything? Thanks again guys.
Old Jun 25, 2004 | 05:10 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
nope the thing is plug and play, I was converting from carb so I had to use a tpi sender, but if you already have that harness you are good to go..
as for price, I bought mine from jegs.. didn't really bother to shop around..
Old Jun 25, 2004 | 07:26 PM
kevinc's Avatar
Car: 1982 Z28
http://www.autoperformanceengineering.com/
or
http://www.racetronix.com/
I got my Walbro hi-pressure pump from the first place, direct bolt-in and it works great.
Old Jun 25, 2004 | 07:54 PM
pasky's Avatar
Damn, that first website is a heck of a lot cheaper than the others. Can ya point me in the right direction on what exactly to get on the first site you posted? Thanks.
Old Jun 26, 2004 | 12:43 PM
kevinc's Avatar
Car: 1982 Z28
FPG003 is the kit I got, mounts right onto the 3rd gen in-tank assembly and includes a wiring pigtail to plug into the 3rd gen fuel pump connector...no soldering, no splicing, no cutting.
I ran the pump for a year with my TPI engine, and now with my LS1...it's happy either way.
Old Jun 26, 2004 | 02:24 PM
pasky's Avatar
Nice, $113 Shipped. Thanks again guys. Just ordered .
Old Jun 26, 2004 | 03:28 PM
kevinc's Avatar
Car: 1982 Z28
Good luck w/ the swap dude, should be the last pump you'll ever buy. They're a gerotor design instead of the traditional roller-vane and they'll take abuse. I've starved mine on corners road-coursing it, filled the tank with nice sun-heated fuel, and it just keeps coming back for more.
Making 39psi or whatever the LT1 runs at, that pump should last forever.
Old Jul 9, 2004 | 01:01 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Do you really need the extra wiring/relay that the racetronix kit has for another $70?
According to my scanner I always have alt output voltage to my fuel pump...?
Old Jul 9, 2004 | 08:54 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I got mine from www.musclemotors.com a while back for $90 shipped. You have to email them a part number or call them up, but they were the cheapest back then. I haven't put it in yet but I am going with a baffled tank and a few other things while I'm back there.
Old Jul 10, 2004 | 03:27 AM
Racetronix's Avatar
The reading is not actually at the fuel pump.
The harness is required for high HP levels where you will be pushing the limits of the Walbro pump. The extra voltage buys you more headroom / safety zone. In some cases factory wiring can be an issue do to the age of the 3rd gens. The Racetronix harness takes the pump load off of the factory wiring.
Old Jul 10, 2004 | 07:15 PM
I helped a friend install the kit on his '89 GTA... lined up great.
The kit is designed for the L98, and the pictures justify that, except my battery and alternator are on the other side.
I wasn't looking forward to having more wires looping over my tranny...
I am borderline with the stock fuel pump, which is why I asked.
Any method to the kit that will make it a little more friendly for the V-belt setups?
Old Jul 11, 2004 | 02:16 AM
Racetronix's Avatar
There are no issues with running the harness over the transmission as the loom and wire are more than able to handle the heat. If you wish you can run the harness down the passenger's side of the car but the harness might be a bit short in order to mount the relay in the recommended location. You could always special order a harness with a bit of extra length by contacting our sales dept.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
