Griffin radiator
Old Jun 27, 2004 | 03:10 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Griffin radiator
Installed the rad yesterday. Intake temp went from 200 degrees before install to 170 after...On sale at Summit for 180 bucks too.
Old Jun 28, 2004 | 05:41 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
That was the single best mod I think I did on my V8 S-10. For $180 I could now idle for 30 minutes+ without going over 200*F
I have one in my 86 Z28 and love it.
Old Jun 28, 2004 | 09:24 PM
86_Dan_Z28's Avatar
Car: 86 Z28
Will this radiator fit if you have ac?
Old Jun 29, 2004 | 01:32 AM
Good question...I took mine out long ago. I believe it will cuz the ac lines go around the side of the rad dont they? And the condensor goes up against the rad. You will need to add a tranny cooler if you have an automatic as there are no provisions for tranny lines or heater core lines on the aluminum rad.
Old Jun 29, 2004 | 01:37 AM
Heres a thread with a pic of John's griffin rad. He has ac, so I would say yes... https://www.thirdgen.org/techbb2/sho...hreadid=247826
Old Jun 30, 2004 | 07:33 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
So no more heater core??
Old Jun 30, 2004 | 10:10 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Find this guy on e-bay, even if he does not have a thirdgen rad listed at the moment
radman1953
Custom made alum. rads for ANYTHING!
Mine included OEM type tranny cooler + heater hose connections
Way cheaper than anything else I found! excellent fit --quality --price-- communication-- 100% positive feedback on e-bay--TOTALLY positive transaction/experiance for me! Highly recommended!
I am one of the most critical people you will find on this board and I usually don not recommend many things to people, but I was totally impressed with this guy from start to finish!
slight mod to top support as all thicker aftermarket rads require. rest of it was drop in.
Old Jun 30, 2004 | 10:32 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Although I don't have AC, I still have the condenser in my car, and the griffin fits fine.
Old Jun 30, 2004 | 03:30 PM
I took mine out for now but you can hook your lines up to the intake and water pump. You should have provisions for both lines.
Old Jul 2, 2004 | 08:02 AM
Car: 91Z
Ohh ok.
Old Jul 8, 2004 | 10:48 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
0101010101
double post
Old Jul 8, 2004 | 10:49 PM
DTL504's Avatar
I just bought a Brand New Griffin Radiator from a guy off Ebay for $149.00 with $10.00 shipping total $159.00. Give him a try if you are looking for a Radiator. It comes new in Griffin box and instruction no second blemish....
Griffin Radiator
Old Jul 9, 2004 | 09:44 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I use the griffen 31x19 universal too, works fine, a/c blows cool, just had to modify the plastic upper mount a bit.. keeps the engine at 170 on HOT days..
Old Jul 9, 2004 | 04:27 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Griffin Radiator
That's a single 1.25" core version. The one most people get is the dual 1" core version for $189 from Summit.
Just a heads up, not all Griffens are the same, you can get them any way you want them. You can also ask for tripple 1.25" core but that's overkill.
The dual 1.25" core version will require custom upper and lower mounts in a 3rd gen.
Old Jul 9, 2004 | 07:56 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
my lower mounts were fine for the dual core version, it just snugged right in on top of the stock rubber mounts.. it was the upper shroud that required some trimming..
Old Jul 9, 2004 | 07:58 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
you can sort of see it here, though the majority of the trimming was done on the other side.. I am not on my home computer to get that pic..
Old Jul 9, 2004 | 08:15 PM
Engine: 4.0L
You must have the dual 1" core, not the dual 1.25" core version. That's why you were able to trim a little and make the stock mounts work.
Trust me, you cannot use the stock mounts with the dual 1.25" core version.
Old Jul 9, 2004 | 08:58 PM
DTL504's Avatar
Yep
you are correct I have the two rows of 1 in. diameter tubing, but that combine with my 180* thermostat, and Stewart Water Pump Stage Two aluminum it should keep my SBC 400 cool.
The two row 1.25 is about $259.00 from summit.
Old Jul 10, 2004 | 06:08 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
yep, I will eat my crow on that one.. thought it was the dual 1.25 but it is the dual 1".. it does keep a 370 odd rwhp LT1 nice and chilly though..
sheachopper
Jul 31, 2019 11:27 AM
lanceflame44
Sep 25, 2015 12:28 PM
