pcv valve /valve cover question.
Old Aug 15, 2004 | 07:44 PM
JeffC1500TBI's Avatar
.does it matter which side of the block the pcv valve is on?
Old Aug 16, 2004 | 12:42 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Nope, doesn't matter. Only thing that matters is that the PCV "circle of life" is complete.
Old Aug 16, 2004 | 12:53 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
circle of life
Thats a good one :yourock:
Old Aug 16, 2004 | 05:56 AM
ok.. just wondering because.. when I had the engine built the guy ordered the wrong valve covers.. the pcv ended up at the rear of the engine on the ps side instead of the front. I thought if I put that vavle cover on the ds then the pcv ends up at the front and it's closer to route to the tb. only thing is the oil filler/breather will end up at the rear on the ps side.
Old Aug 16, 2004 | 08:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The PCV is supposed to be at the front driver's side, with the oil fill at the rear driver's side. The fresh air side of the PCV system is supposed to be at the rear pass side.
If you have the oil fill at the rear pass side, most likely that valve cover is backwards, and the rocker arms will hit it on the push rod side.
But as far as the PCV function, it doesn't matter which side is which; as long as there's a gozinta for the fresh air on one side, and a cumzotta for the PCV valve itself on the other side, and somewhere to add oil (optional actually since you can add it through one of the others), and the valve covers aren't backwards.
Old Aug 16, 2004 | 10:30 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the prefferd setup is PCV on the drivers side, breather on the passenger side... mostly because the "wind" generated by the spinning crank is helpful...
but its still effective when the components are swapped from side to side.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Ian Irvine
Sep 4, 2015 08:08 AM
