FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
Vacuum Diagrams
Old Sep 1, 2004 | 12:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Vacuum Diagrams
Here's a typical one for computer controlled carb 3rd gens.
Perhaps others can post TBI/TPI types.
Old Feb 11, 2005 | 01:34 AM
bombader's Avatar
Car: 1989 Camaro IROC Z-28
Engine: 2002 LS1
Axle/Gears: 3.08
If any one has a pic from an '85 TPI car I'd appreciate it as well as the Vehicle Emission Control Information label as my car doesn't have them. I tried to get them at my local Pontiac dealer but they said they couldn't get them anymore.
Old Feb 11, 2005 | 12:17 PM
Chrome's Avatar
Car: 92' RS Camaro
My wife has a 84' Pontiac 6000 (amazing good shape body and all), but I had to replace valve cover gaskets and you talk about a NIGHTMARE. I had to track down a vacuum leak on it once and sometimes I felt like ripping the CCC out and putting a holley on, but eventually managed. Graphics like above definitely help out. Great Job 57!
Old Apr 20, 2005 | 11:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Typical of non-CCC export LG4:
Old Jun 2, 2005 | 06:40 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
right now i have a vaccume leak or two. and i have removed a few vaccume using components and realy need a diagram like this for a 2.8L MPFI car. if anyone can help i would appreciate it.
Old Jun 2, 2005 | 09:05 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
I'm assuming it's the 86 in your sig:
Also, for anyone who is looking for vacuum diagrams for your 3rd gen, just go to link below. It's got all the vacuum diagrams for the different engines over the years. Here it is: http://www.autozone.com/servlet/UiBr...3d80163807.jsp
Old Jun 4, 2005 | 01:51 AM
Xophertony's Avatar
Axle/Gears: n/a
THANKYOU!!!
i added the link to my sig. that way anyone who sees one of my posts will know where to go.
Old Jun 13, 2005 | 06:25 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Vacuum Tube
Do any of the diagrams tell you what size vacuum tubing needs to be used? Looking at mine it doesn't look like a standard size or would it really not matter?
Old Jun 13, 2005 | 07:01 PM
Apeiron's Avatar
Engine: 383 Carb
As long as it fits the ports.
Old Jun 15, 2005 | 03:10 PM
confucius101's Avatar
do you have any nice large shot's like that of the 91 3.1 setup?
Old Mar 26, 2007 | 06:48 AM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Re: Vacuum Diagrams
I need to know (preferably a picture) in detail where the "TO HVAC" goes exactly. I'm thinking this might be why I can only get air to come out of the defroster vents no matter what I have it set on.
Old May 9, 2007 | 05:00 PM
vzfox's Avatar
Re: Vacuum Diagrams
I am in need of a vacuum diagram for a 1983 Chev Camaro V6 2.8L
Old Jun 7, 2007 | 04:51 PM
ronnieswitch's Avatar
Re: Vacuum Diagrams
We desperatly need a good diagram of emmisions routing for a 1990 V8 TBI 5.0
I am new on this site and sure it's here somewhere, just cannot find it, if someone knows where to find it, please help! Thanx!
Old Jun 7, 2007 | 04:56 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Vacuum Diagrams
Here are all of them listed
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Sep 21, 2007 | 11:42 PM
Pepito's Avatar
Re: Vacuum Diagrams
Friends I'm in need of a diagram of hose that go from the air tubes to the polition pump. I have a 1987 Camaro Iroc tnat has the 2 belt set up and I made it the one belt set up and I forgot how the hoses from the air tube go. So I need some help. Thanks.
Old Jul 14, 2008 | 12:18 PM
coyote452002's Avatar
Re: Vacuum Diagrams
Guys I just bought a 91 Camaro Z28 Convertible, it had a 305 TBI. I did away with it and I installed a TPI system from a 1989 IROZ with a Mass Air Flow Sensor . I kept the original 1991 vent canister wich has a different diagam. My question is, should I set the vacuum lines up as the TPI 90-92 or should i find the vent canister for a 86-89 TPI?????
Old Oct 30, 2008 | 03:07 PM
piercesteve2000's Avatar
Car: 86 camaro sport coupe
Engine: LG4 5.0L V8
Transmission: automatic
Re: Vacuum Diagrams
ive got an 86 305, berlinetta. the vacuum diagram has lettering on the carburetor. how do i identify which of these letters represent the vacuum on my carb, i know of at least one that is above the other. the diagram just shows a left to right and such.
Old Mar 6, 2009 | 10:04 AM
blue68nova's Avatar
Car: 1982 z28
Engine: 305 crossfire injection
Transmission: at
Re: Vacuum Diagrams
I am repair my 1982 z28 that has a crossfire injection system. I can not find the EGV vacuum control solenoid anywhere. Does some body know where i can get one of these? Deal is telling me that they no longer make them and will be very hard to find.
Old Mar 9, 2009 | 01:24 PM
z28crazy's Avatar
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
Re: Vacuum Diagrams
Do you a version of this diagram for cars without emissions equipment or more specific with the the airpump and stock air cleaner removed?
Also can anyone tell me the name of the sensor that is near the thermostat and has two vaccum lines attached to it?
Old Mar 30, 2009 | 08:48 PM
schilke05's Avatar
Car: 88 camaro
Engine: 2.8
Transmission: auto
Re: Vacuum Diagrams
hi i need a emissions diagram for a 2.8 tbi cant find one any where. can only find a carb diagram. the auto zone link dosent work.
Old May 21, 2009 | 01:12 PM
jlcz28's Avatar
Car: 91 z28
Engine: 5.7 tpi
Re: Vacuum Diagrams
Old May 23, 2009 | 07:38 AM
jlcz28's Avatar
Car: 91 z28
Engine: 5.7 tpi
Re: Vacuum Diagrams
did you ever get this problem fixed? b/c I'm having the same problem. I know it was awhile back but if you could help me out I;d appreciate it.
Old Jul 11, 2009 | 08:54 AM
jetsziarnick's Avatar
Re: Vacuum Diagrams
I need help. Can somebody please show me a vacumm diagram for a 1982 camaro with a V8 305 CROSSFIRE. Cross fire is the key.
Old Jul 12, 2009 | 01:47 PM
breamrules's Avatar
Re: Vacuum Diagrams
A vaccuum diagram for an '89 Formula (5.7) with TPI would be outstanding.
Old Aug 6, 2009 | 08:31 PM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
Re: Vacuum Diagrams
Old Sep 3, 2009 | 06:49 PM
tjerde's Avatar
Re: Vacuum Diagrams
I recently bought my son a 1983 berlinetta with the 2.8. It ran like crap, so I started with the fuel filter, cap and rotor, plugs etc..... you know the typical stuff, and it didn't get any better. It's carberated and if I hold my hand over the carb it runs better..... any suggestions???
Old Sep 3, 2009 | 09:40 PM
96gmc1500's Avatar
Re: Vacuum Diagrams
hi im trying to figure out the vacuum diagram for a 91 z28 5.7 camaro im not sure if one of the 2 that are on here are it or nit. im trying to work on a friends car. when cold it dont wanna idel for crap but once warmd up my friend says it idles fine. i found a few vacum lines brok and missing. was looking for some help. if possible thnx. jason
Old Oct 22, 2009 | 09:02 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Vacuum Diagrams
does nay one have a crossfire vacuum diagrahm
Old Oct 24, 2009 | 06:40 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
Re: Vacuum Diagrams
would a v6 carb look the same?
Old Nov 2, 2009 | 07:16 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Vacuum Diagrams
none of the above posted links work today . autozone has blocked them for some reason , or maybe just too old . does anyone have current ones ???
Old Nov 2, 2009 | 08:43 PM
JT's Avatar
JT
Community Administrator
Re: Vacuum Diagrams
It appears you must have a (free) registered account with AutoZone in order to access that information.
Going here:
http://www.autozone.com/autozone/rep...nfoLanding.jsp
Then here:
http://www.autozone.com/autozone/myz...ipBenefits.jsp
Once you have an account, you can then access the vacuum diagrams under Emission Controls and then Vacuum Diagrams
Old Dec 20, 2009 | 09:56 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: TPI Vacuum Diagrams
Here are 2 different vacuum diagrams for the TPI system. Just follow the link. https://www.thirdgen.org/forums/post...48-post12.html
Old Jan 4, 2010 | 10:35 AM
lopezisgod's Avatar
Car: 86 iroc-z, 78 z28, 91 z28
Engine: 355-carb, 350-carb, 350-TPI
Transmission: 5speed, at, 5 speed
Axle/Gears: 3.42, 3.42-stock, 3.42-1LE
ThirdGen VACUUM DIAGRAMS INSIDE!!!
Not sure where to post this MODERATORS.. but i figured since it look me like 2-3 days to find these diagrams it should be made a sticky.. as it seams like its important yet extreamly useful info to alot of people..
Here are 2 zip files that have EVERY vacuum diagram i could find for third gens..
if there are anymore please post as i cant find anymore..
File Type: zip
File Type: zip
Old Feb 15, 2010 | 07:56 PM
Theman0188's Avatar
Car: 76 Corvette Stingray
Axle/Gears: Stock
Re: ThirdGen VACUUM DIAGRAMS INSIDE!!!
you are my hero
Old Feb 15, 2010 | 10:50 PM
lopezisgod, where did you get these diagrams at? I ask because there is one diagram which is label "85-86 5.0L TPI", well it is completely wrong, false to the max. My 86 TPI vapor canistor is on the driverside, not the passenger side. On the passengerside is the battery.
Old Feb 15, 2010 | 10:51 PM
Re: Vacuum Diagrams
I must admitt though, good lookin.
Old Mar 2, 2010 | 09:36 PM
novadude73's Avatar
Re: Vacuum Diagrams
Going here:
Then here:
This Infomation was very helpful Thank You.
Old Mar 27, 2010 | 10:40 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: Vacuum Diagrams
Ill be figuring out sizes for the following diagram. Since I busted my EGR vacuum hoses, might as well do the rest too.
Fig. 21: 1988-1992 5.0L Throttle Body Injection; auto trans.
EDIT:
Lengths will vary depending on how you route. Also I would go to figure that sizes are the same for each part, just not the lengths.
Map Sensor- 1/4"
EGR Solenoid- 3/16"
EGR Valve- 3/16"
PCV- 3/8"
Canister Top- 1/4"
Canister Bottom- 5/16"
-Y Connector- 5/16" Main, Split to 3/16" Secondary
-Canister Bottom Y (Small Hose)- 3/16"
-Canister Bottom Y (Large Hose)- 5/16"
Brake Booster- 3/8"
3/16" = 3ft = 4mm
1/4" = 5ft = 6mm
5/16" = 1ft = 8mm
3/8" = 3ft = 10mm
Buying all from Hose Techniques
Last edited by I H8 WWD; Mar 28, 2010 at 07:20 PM. Reason: Added sizes and lengths
Old Apr 19, 2011 | 11:12 AM
tx89fbirdgal's Avatar
Thanks for the diagrams, but do you have access to a picture of the EGR solenoid? I have never had to replace this thing and I most likely need to. 271, 000 miles, no replace. Have replaced the EGR valve every 4 years. Anyway, anything you can do will be appreciated. I am the original owner of an 89 Formula with 5.7 tpi. I work on myself when I can.
Thanks,
Barbara
Old Aug 7, 2011 | 07:58 AM
joeleugers's Avatar
Re: Vacuum Diagrams
Looking for a vacuum hose routing diagram for 89 IROC 5.7 TPI.
Old Aug 7, 2011 | 08:58 AM
Re: Vacuum Diagrams
follow this link to find your vac. Line diagram. http://www.chevythunder.com/fuel%20i...um%20lines.htm
Old Aug 7, 2011 | 11:28 AM
KITT1983's Avatar
Re: Vacuum Diagrams
any one know where i can get a vacuum manometer to balance my crossfire tbis
Old Aug 7, 2011 | 09:05 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: Vacuum Diagrams
this is awesome, hopefully itll help me understand how mine goes back together LOL ive deleted air and egr
Old Aug 8, 2011 | 11:57 AM
DJK90IrocZ's Avatar
Car: 90 Camaro IROCZ
Engine: 5.7L TPI
Transmission: Auto 4 speed
Re: Vacuum Diagrams
These diagrams are awesome for reference data.
Does it matter which end of the lines hook up to the EGR solenoid? I have a code 32 EGR code.
Thanks!
Old Aug 8, 2011 | 01:47 PM
Re: Vacuum Diagrams
When I get home, ill send u a troubleshooting guide for your TC. 32.
Old Aug 13, 2011 | 04:12 PM
DJK90IrocZ's Avatar
Engine: 5.7L TPI
Re: Vacuum Diagrams
Hey Chevy86...
I figured out what the problem was. I guess for some reason there is NO vacuum suction from the hose under my throttle body. I used a different vacuum source and hooked up my EGR solenoid from the 95 Caddy 4.9L engine and now there is NO SES light!!!
I wanted to ask you a different Q though....
Have you ever noticed your volt gauge drop below the 13 when you have the AC on and are sitting at a traffic light?
I replaced the belt with a brand new Dayco and have all the stock items installed.
Any issue with the battery going to be Dis-chaged when the needle goes below 13 at idle? It doesnt do it when I am cruising down the road.
I appreciate any help or advice.
Old Aug 13, 2011 | 05:57 PM
Re: Vacuum Diagrams
Originally Posted by DJK90IrocZ
Hey Chevy86...
Ohh Dang!!! I would use explicit words but the thread must stay PG-13. I completely forgot to help you out man. My apologies. Good for you on locating the problem. As for the voltage gauge, yes. I dont have a/c but I do have a 800 watt bass sound system. I have a 3 month old reman alternator. Either at a dead stop or while driving, my voltage drops down to about 8 volts (according to the volt gauge). But when I have the system off, my gauge reads 12-13 volts. Your below 13 volts issue will and should not be an issue. The only time this will affect is during a extremely cold winter because the "cold cranking amps" drops. But dont worry too much. If it bothers you that much, park it, turn on a/c to full blast. Once the voltage drops below 13 on the gauge, test the batteries voltage with a voltmeter. Note the voltage reading on the multi/voltmeter. Then go back inside and note the voltage on the gauge. The difference that you will see is pretty much common with our aging cars. This is because of the wiring. As time goes by, the current has a tougher time traveling down the wire do to contamination and corrosion. the down fall is the drop in voltage because the current has less and less area to travel on/in. So the there you have it. If the Camaro ever dies on you because the voltage drops too much, then you should be concerned. The best battery and highly recommended for our 3rd gens is the Optima Battery. Its expensive but it is the most reliable IMO.
Old Aug 15, 2011 | 02:22 PM
joeleugers's Avatar
Re: Vacuum Diagrams
Thanks for the help!
Old Aug 26, 2011 | 12:21 AM
keepthefaith's Avatar
Re: Vacuum Diagrams
Just FYI, the EGR solenoid valves I have seen must be connected correctly. The vacuum connector centered on the solenoid body must be connected to the vacuum source and the other line must go to the EGR valve. This is because when the solenoid is not energized, the EGR side is vented to air through a small orifice and filter so that the valve will close quickly. If you get these lines wrong, you will have a vacuum leak when not energized, and the EGR valve will stay open long after it is supposed to close!
KTF
Old Aug 26, 2011 | 08:47 AM
KITT1983's Avatar
Re: Vacuum Diagrams
hey do you know where i can get an egr solenoid for a 1983 crossfire firebird
