fiberglass and fleece
Old Sep 14, 2004 | 08:48 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
i am going to build a center console and would like to know where i can get some fleece(i think thats what its called)to stretch over the mdf.any help help would be appreciaed.also what knid of resin should i use.
thanks
Old Sep 15, 2004 | 08:53 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Walmart or about any other place that has a craft section sells fleece usually. I used plain old cotton white fleece for my project cause it was the cheapest. :-)
Check out this link to the car audio board https://www.thirdgen.org/techbb2/sho...hreadid=259377
You're gonna have to use fiberglass too. Fleece alone isn't that strong heck I could put my thumb through it probably if I tried. It gets pretty brittle after you get the resin cured on it.
For resin try going to a local boat shop or I've heard you can even get it from Home Depot or a store like that. I know Walmart/Autozone etc sell it in quarts but look to use at least acouple quarts and for around 8 bucks/quart that gets expensive quick. I would recommend finding a local place and getting it in a Gallon. If all else fails check out online stores like www.uscomposites.com
As for the glass there's not going to be any pressure involved so no need to go overkill on biaxial or heavy woven stuff... acouple 3 layers of plain mat will probably be enough unless you're one of those people that like to lean on the center console like me. Again buying from places like Walmarts adds up quick since it's 4 bucks for only 8 sq feet.
Old Sep 15, 2004 | 09:03 PM
emtcee's Avatar
Car: 67 camaro
Transmission: t56
thanks for the info.yeah i knew i had to use some mat along with the fleece , i just wasn't sure where i could get the fleece.thanks again....
Old Sep 16, 2004 | 06:07 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.fibreglast.com
http://www.fibreglast.com/phpBB2/ind...0e340842924966
You can find and buy everything you need there if you cant find it local.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
